I’d love if when a project is running you can toggle the priority modes from normal to high and vice versa by tapping the push notification widget.
Simple as that. Thinking of home made alarm system, toggle to normal when @ home toggle high when leaving.
In combonation with the GEO-GPS widget, you could have notification turn on or off, and always set in high/priority mode?
It’s a solution yea, however just having the high priority setting on will cause a larger battery drain on the phone. Kind of that that I wanted to avoid that.
Edit: I also want them always on for my system
