Notification on local server
Does anyone know why not the local server does not make notifications.
I have pord forwrding both ports (8080 and 9443).
Port forwarding isn’t needed to allow notifications on local server.
Can you ping the outside world from your local server?
Is there a chance that you’ve been temporarily blocked by the Google notification service for spamming the service?
Can you ping the outside world from your local server? YES
Is there a chance that you’ve been temporarily blocked by the Google notification service for spamming the service? How I now??
Have you been trying to send notifications every few seconds for the past few hours?
What do your server logs show?
Have the notifications been processed?
What does the response from the notification service say?
In which logs I find this information.
I have blynk.log
status.log
worker.log
It should be in logs/blynk.log but you might need to change the log.level in server.properties to trace or debug the restart the server and re-try the notification before you see sufficient detail to be of use.
