Thanks Pete,
I just sorted the #16.
The only challenge now is, sending an email when temperature is reached to 50.
Thanks Pete,
No, thatâs why I saidâŚ
Put these declarations at the top of your code, not scattered throughout it in random places.
Remove this delay.
I dont think tweets are supported anymore.
This codeâŚ
is missing a closing curly bracket }
Hi Pete,
Here is my Sketch and I am getting the following error
#include <DHT.h>
#define trig D2
#define echo D1
long duration;
int distance;
char auth[] = "Token";
char ssid[] = "wifi";
char pass[] = "pwd";
#define DHTPIN D5 // What digital pin we're connected to
DHT dht(DHTPIN, DHTTYPE);
void sendDHTSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
if (t > 50.0) {
Blynk.email(âmymail@gmail.comâ, âhigh Temperatureâ, âHigh Temp!â);
Blynk.notify(âAlert : High Temp!â);
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
int flag=0;
void notifyOnFire()
int isButtonPressed = digitalRead(D3);
if (isButtonPressed==1 && flag==0) {
Serial.println("Warning Fire Detected");
Blynk.email("mymail@gmail.com", "Fire Alert", "fire detected!");
Blynk.notify("Alert : Fire Detected");
flag=1;
else if (isButtonPressed==0)
flag=0;
pinMode(trig, OUTPUT); // Sets the trigPin as an Output
pinMode(echo, INPUT); // Sets the echoPin as an Inpu
pinMode(D3,INPUT_PULLUP);
timer.setInterval(1000L,notifyOnFire);
timer.setInterval(15000L, sendSensor);
dht.begin();
timer.setInterval(10000L, sendDHTSensor);
void sendSensor()
digitalWrite(trig, LOW); // Makes trigPin low
delayMicroseconds(2); // 2 micro second delay
digitalWrite(trig, HIGH); // tigPin high
delayMicroseconds(10); // trigPin high for 10 micro seconds
digitalWrite(trig, LOW); // trigPin low
duration = pulseIn(echo, HIGH); //Read echo pin, time in microseconds
distance = duration * 0.034 / 2; //Calculating actual/real distance
Serial.print("Distance = "); //Output distance on arduino serial monitor
Serial.println(distance);
if(distance >= 5)
Blynk.email("mymail@gmail.com", "distance", "distance reached!");
Blynk.notify("distance reached ! ");
Blynk.virtualWrite(V0, distance);
//delay(1000); //Pause for 1 seconds and start measuring distance again
Sorry if i had missed out anything
The compiler will point you to the location of the problems, but itâs most likely these quotation marksâŚ
Youâll see that they are different to the "
quotation marks that you have used in the rest of your sketch.
Hi Pete,
Thanks I just noticed that,
Iâll correct it and recompile
Will update you.
Regards
KM
Hi Pete,
I am still getting error
âa function-definition is not allowed here before â{â tokenâ
I included int flag=0; but still getting the same error,
below is my latest sketch
#include <DHT.h>
#define trig D2
#define echo D1
long duration;
int distance;
char auth[] = "AUTH";
char ssid[] = "wifi;
return;
if (t > 50.0) {
Blynk.email("mymail@gmail.com", "Temp Alert", "Check Temperature!");
Blynk.notify("Alert : Check Temperature");
int flag=0;
void notifyOnFire()
Blynk.email("mymail@gmail.com", "Fire Alert", "fire!");
flag=1;
flag=0;
dht.begin();
void sendSensor()
if(distance >= 5)
Blynk.tweet("My Arduino project is tweeting using @blynk_app and itâs awesome!\n #arduino #IoT #blynk");
Blynk.email("mymail@gmail.com", "Safety Alert", "distance reached!");
Blynk.notify("distance ! ");
Your problem is a missing closing curly bracket in the sendDHTSensor()
function.
If you laid-out your code better, with proper indents, and stopped putting your opening curly brackets at the end of a line, then youâd be able to spot these issues easier.
This is the fixed functionâŚ
return;
if (t > 50.0)
Hi Pete,
Thanks for the sketch, iâll try in short while.
Regards
KM
Hi Pete,
My apologies on the delay.
your code fixed everything, things are working fine now, Thanks a lot.
Regards,
KM
