Nodemcu stays in connect but it get divice offline within a day
Just search the forum for Blynk.config and Blynk.connect, or read the Legacy documentation.
Sir, I have changed the coding according to your saying and Blynk.config, Blynk.connect and the Legacy documentation.
Please say it whether it is correct or wrong.I appreciate your help.
//#define BLYNK_MAX_SENDBYTES 128
char ssid[] = "user name ";
char pass[] = "password";
char auth[] = "auth token";
int val = 0;
int pirState;
int x = 0;
WidgetLCD lcd(V1);
WidgetLCD lcd2(V5);
WidgetLCD lcd3(V7);
int ReCnctFlag;  // Reconnection Flag
int ReCnctCount = 0;
BLYNK_WRITE(V0)
  if(param.asInt() == 0){
    pinMode(D0, LOW);
      lcd.print(0, 0, "SWITCH 01 OFF");
  }else{
     pinMode(D0, HIGH);
      lcd.print(0, 0, "SWITCH 01 ONN");
BLYNK_WRITE(V2)
    pinMode(D1, LOW);
     lcd.print(0, 1, "SWITCH 02 OFF");
  }else{
     pinMode(D1, HIGH);
      lcd.print(0, 1, "SWITCH 02 ONN");
BLYNK_WRITE(V3)
    pinMode(D5, LOW);
  lcd2.print(0, 0, "SWITCH 03 OFF");
  }else{
     pinMode(D5, HIGH);
 lcd2.print(0, 0, "SWITCH 03 ONN");
#define pirPin D4
int pirValue;
char replybuffer[255];
int pinValue;
SoftwareSerial sim(10, 11);
int _timeout;
String _buffer;
BLYNK_WRITE(V4)
    pinMode(D3, LOW);
     lcd2.print(0, 1, "SWITCH 04 OFF");
  }else{
     pinMode(D3, HIGH);
      lcd2.print(0, 1, "SWITCH 04 ONN");
BLYNK_WRITE(V6)
 pinValue = param.asInt();
    lcd3.clear();
     lcd3.print(0, 1, "HUMAN OFF");
  }else{
      lcd3.print(0, 1, "HUMAN ONN");
BLYNK_CONNECTED(){
  Blynk.syncAll();
int calibrationTime = 30;
long unsigned int lowIn;
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int PIRValue = 0;
  _buffer.reserve(50);
  Serial.println("System Started...");
  pinMode(D0, OUTPUT);
  pinMode(D1, OUTPUT);
  pinMode(D5, OUTPUT);
  pinMode(D3, OUTPUT);
  pinMode(D0, LOW);
  pinMode(D1, LOW);
  pinMode(D5, LOW);
  pinMode(D3, LOW);
  pinMode(pirPin, INPUT_PULLUP);
   Blynk.connectWiFi(ssid, pass);  // Blynk WiFi setup
  Blynk.config(auth, "blynk-cloud.com", 8080);
  Blynk.connect();
//  Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8080);
  lcd.clear();
  timer.setInterval(2500L, notifiaction);
void notifiaction()
  if(pinValue){
    int sensor = digitalRead(pirPin);
    if (sensor == 1) {
      Serial.println("WARNING! Please check your security system");
         Blynk.notify("WARNING! Please check your security system");
      lcd3.print(0, 0, "MOTION DETACTED..");
    }else{
       lcd3.print(0, 0, "MOTION  NOT DETACTED..");
```⸮⸮System Started...
[65] Connecting to Aflal
[4294] Connected to WiFi
[4294] IP: 192.168.162.48
[4294]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.6.1 on ESP8266
[4372] Connecting to blynk-cloud.com:8080
[4787] Ready (ping: 168ms).```
You had a working Wi-Fi connection system in your original sketch. Re-instate that snd remove this.
Hi sir i changed wifi coding
Please check it sir
char ssid[] = "xxxxxx";
char pass[] = "xxxxxxxxx";
char auth[] = "xxxxxxxxxc";
int val = 0;
int pirState;
int x = 0;
WidgetLCD lcd(V1);
WidgetLCD lcd2(V5);
WidgetLCD lcd3(V7);
BLYNK_WRITE(V0)
    pinMode(D0, LOW);
  }else{
     pinMode(D0, HIGH);
BLYNK_WRITE(V2)
    pinMode(D1, LOW);
  }else{
     pinMode(D1, HIGH);
BLYNK_WRITE(V3)
    pinMode(D5, LOW);
  }else{
     pinMode(D5, HIGH);
#define pirPin D4
int pirValue;
int pinValue;
int _timeout;
String _buffer;
BLYNK_WRITE(V4)
    pinMode(D3, LOW);
  }else{
     pinMode(D3, HIGH);
BLYNK_WRITE(V6)
    lcd3.clear();
  }else{
BLYNK_CONNECTED(){
  Blynk.syncAll();
int PIRValue = 0;
void initWiFi() {
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, pass);
  Serial.print("Connecting to WiFi ..");
    Serial.print('.');
  //The ESP8266 tries to reconnect automatically when the connection is lost
  WiFi.setAutoReconnect(true);
  WiFi.persistent(true);
  pinMode(D0, LOW);
  pinMode(D1, LOW);
  pinMode(D5, LOW);
  pinMode(D3, LOW);
  initWiFi();  // Blynk WiFi setup
  Blynk.connect();
  lcd.clear();
void notifiaction()
  if(pinValue){
    if (sensor == 1) {
    }else{
That looks better.
Now I’d add a timer that checks if the WiFi is connected, and if Blynk is connected, and if not then do a re-connection, rather than a restart like you had originally.
You should also introduce a flag so that you only send one notification for each motion detection event, to avoid spamming yourself with notifications and to avoid exceeding the 1 notification every 5 second limit.
I changed the coding as per you said .
char ssid[] = "xxxxxxxx";
char pass[] = "xxxxxxxx";
char auth[] = "xxxxxxxxxxxxxxx";
int val = 0;
int pirState;
int x = 0;
WidgetLCD lcd(V1);
WidgetLCD lcd2(V5);
WidgetLCD lcd3(V7);
BLYNK_WRITE(V0)
    pinMode(D0, LOW);
  }else{
     pinMode(D0, HIGH);
BLYNK_WRITE(V2)
    pinMode(D1, LOW);
  }else{
     pinMode(D1, HIGH);
BLYNK_WRITE(V3)
    pinMode(D5, LOW);
  }else{
     pinMode(D5, HIGH);
#define pirPin D4
int pirValue;
int pinValue;
int _timeout;
String _buffer;
BLYNK_WRITE(V4)
    pinMode(D3, LOW);
  }else{
     pinMode(D3, HIGH);
BLYNK_WRITE(V6)
    lcd3.clear();
  }else{
BLYNK_CONNECTED(){
  Blynk.syncAll();
int PIRValue = 0;
int PIRflag = 0;
void initWiFi() {
    Serial.print('.');
  pinMode(D0, LOW);
  pinMode(D1, LOW);
  pinMode(D5, LOW);
  pinMode(D3, LOW);
  Blynk.connect();
  lcd.clear();
void notifiaction()
  if(pinValue){
    if (sensor == 1) {
      if(PIRflag == 0){
      PIRflag = 1;
    }else{
        PIRflag = 0;
Really? Maybe you posted the wrong code?
Can you point out what’s wrong on here ?
Where is this in the sketch you posted?
Sir, I cannot understand what you are saying accordin to this post.
Can you please tell in a way that i could easily understand? I really appreciate your help.
Go back to the original code you posted.
Look at the void loop and locate the part that checks if there is a WiFi connection and restarts the device of not.
Put this on a function, remove the restart part and replace it with a reconnection call, and do the same with a check to see if Blynk is connected.
Call this function with a timer.
Is it okay now? Are you telling me to put in this method?
char pass[] = "xxxxx";
char auth[] = "xxxxxxxxxxx";
int val = 0;
int pirState;
int x = 0;
WidgetLCD lcd(V1);
WidgetLCD lcd2(V5);
WidgetLCD lcd3(V7);
BLYNK_WRITE(V0)
    pinMode(D0, LOW);
  }else{
     pinMode(D0, HIGH);
BLYNK_WRITE(V2)
    pinMode(D1, LOW);
  }else{
     pinMode(D1, HIGH);
BLYNK_WRITE(V3)
    pinMode(D5, LOW);
  }else{
     pinMode(D5, HIGH);
#define pirPin D4
int pirValue;
int pinValue;
int _timeout;
String _buffer;
BLYNK_WRITE(V4)
    pinMode(D3, LOW);
  }else{
     pinMode(D3, HIGH);
BLYNK_WRITE(V6)
    lcd3.clear();
  }else{
BLYNK_CONNECTED(){
  Blynk.syncAll();
int PIRValue = 0;
  pinMode(D0, LOW);
  pinMode(D1, LOW);
  pinMode(D5, LOW);
  pinMode(D3, LOW);
  Blynk.connect();
  lcd.clear();
  timer.setInterval(2500L, reConnect);
void reConnect(){
    Serial.print('.');
void notifiaction()
  if(pinValue){
    if (sensor == 1) {
    }else{
```Connecting to WiFi ..[68]
    ___  __          __
[128] Connecting to blynk-cloud.com:8080
[5128] Connecting to blynk-cloud.com:8080
[5397] Ready (ping: 123ms).
WARNING! Please check your security system```
No, not really, but I’m growing tired of explaining what you should do and you only taking-in part of the message.
All the information you need is in this topic, maybe you should just take the time to re-read it?
Sir, I cannot understand what you were saying even if i re-read it.Will it work if i use the example sketch?. I am a beginner in coding. Early i used arduino and it worked for 6 months. After that it didnt work. Therefore, I chose nodemcu but it goes offline after 1-2 days and I looked for solution for 3 months and found none.Can you please patiently tell me how it should be done permanently?. Thank you. I appreciate your help :pray:.
Maybe something like this.
BLYNK_CONNECTED() {
  Serial.println("Cconnected");
  Blynk.syncAll();
  ReCnctCount = 0;
void initWiFi() {
    Serial.print('.');
     if(WiFi.status() != WL_CONNECTED)
       Serial.print("WIFI Reconnecting");
       initWiFi();  //  WiFi setup
    else if (Blynk.connected())
       Blynk.run();   // If connected run as normal
   else if (ReCnctFlag == 0)
    ReCnctFlag = 1;  // Set reconnection Flag
    Serial.println("Starting reconnection timer in 30 seconds...");
    timer.setTimeout(30000L, []() {  // Lambda Reconnection Timer Function
      ReCnctFlag = 0;  // Reset reconnection Flag
      ReCnctCount++;  // Increment reconnection Counter
      Serial.print("Attempting reconnection #");
      Serial.println(ReCnctCount);
      Blynk.connect();  // Try to reconnect to the server
      });  // END Timer Function
@Toro_Blanco Thank you so much for replying . I was looking for solution for 3 months. Can i apply this to my original sketch?
Yes, with care to make sure you have all of the variables defined and such.
@Toro_Blanco @PeteKnight Thank you so much for solving a big problem for me.
you code complicate the communication stuff. you can pair blynk.begin with wifimanager easily.
I replaced my original coding with the coding you sent. Will it work perfectly without going offline?
Thank you.
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
char auth[] ="xxxxxxxxxx";
int val = 0;
int pirState;
int x = 0;
WidgetLCD lcd(V1);
WidgetLCD lcd2(V5);
WidgetLCD lcd3(V7);
void initWiFi() {
    Serial.print('.');
BLYNK_WRITE(V0)
    pinMode(D0, LOW);
  }else{
     pinMode(D0, HIGH);
BLYNK_WRITE(V2)
    pinMode(D1, LOW);
  }else{
     pinMode(D1, HIGH);
BLYNK_WRITE(V3)
    pinMode(D5, LOW);
  }else{
     pinMode(D5, HIGH);
#define pirPin D4
int pirValue;
int pinValue;
int _timeout;
String _buffer;
BLYNK_WRITE(V4)
    pinMode(D3, LOW);
  }else{
     pinMode(D3, HIGH);
BLYNK_WRITE(V6)
    lcd3.clear();
  }else{
BLYNK_CONNECTED(){
  Blynk.syncAll();
  ReCnctCount = 0;
int PIRValue = 0;
  pinMode(D0, LOW);
  pinMode(D1, LOW);
  pinMode(D5, LOW);
  pinMode(D3, LOW);
  Blynk.connect();
  lcd.clear();
void notifiaction()
  if(pinValue){
    if (sensor == 1) {
    }else{
Connecting to WiFi ..[69]
    ___  __          __
[129] Connecting to blynk-cloud.com:8080
[5129] Connecting to blynk-cloud.com:8080
Attempting reconnection #1
[39128] Connecting to blynk-cloud.com:8080
[39385] Ready (ping: 126ms).
Cconnected```
