What @Gunner said. Additionally its good to know that
- relays usually are active when the pin is LOW
- esps after reboot usually go up (for 100ms) and then LOW in default.
What I do is initialize all my pins on setup (exactly for those kinds of cases as you describe) so from my setup() function:
pinMode(HEATER_RELAY_PIN_1, OUTPUT); // Set ESP pin to output to the relay
digitalWrite(HEATER_RELAY_PIN_1, HIGH); // activate = LOW, deactivate = HIGH
beyond that you can use e.g. sync with the server as gunner described.
edit: this is also very helpful!
