Thank you.
Just curious to know, the changes came with the new version of library or the latest server ?
m i doing right ?//char server[] = “192.168.1.169”; before
//Blynk.begin(auth, ssid, pass, server, 8080); before
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,169), 8080); After
But even after this the serial monitor shows error, never outputs
connected to 192.168.1.114
Blynk version (with Blynk logo )
connecting to 192.168.1.114
ping 1ms
this regular process is not happening !!
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v614f7c32
~ld
this is all i am getting.
but surprisingly the nodemcu connects to the server, but the code is not working as it should. (this is the same code i was using from many months) and was working fine.
Is it something to do with the Arduino IDE or is it with my Nodemcu ?
i also updated the blynk server to the latest build. But am not getting the thing right.
