NodeMCU keeps connecting
I just got a new NodeMCU and when I try to connect it with the tutorial code it displays this message:
“⸮⸮=s⸮⸮[262] Connecting to Web2”
And nothing happens afterwards…
Rate is at 9600
What am I doing wrong?
My crystal ball states you have a bug in your code at… Line 46…:wink:
Seriously… Could you provide more details like your code (properly formatted) rather than “nothing happens”?
Ok, so I’m using the tutorial code:
char auth[] = "hiding for this post";
char ssid[] = "Web2";
char pass[] = "88881111";
  // to avoid delay() function!
Did you add the Blynk Libraries according the docs?
Yeap
it seems that can’t connect to your wifi.
check esp power source, check signal strength, reset router, etc
Its all working, tried all my bands, I think it’s on the arduino side since there’s the strange characters before the message
no, the strange caracters are normal at the beginning of serial output with esp82 boards.
do you have more esp boards? maybe you could try another one?
No :C I have an UNO, this is my first time with Wifi
hm, than make sure the ssid and pass are correct.
did you tried restarting the router?
maybe there is mac filter enabled?
Turns out that restarted the modem worked… I feel dumb… Thanks guys :v:
Good! Enjoy Blynk!
And change that serial rate to 115200 :wink:
