http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "YourTemplateID"
char pass[] = "YourPassword";
Do you have the latest version of the library (1.1.0) installed?
#define BLYNK_TEMPLATE_ID "TMPxxxxxx"
#define BLYNK_TEMPLATE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
Should be at the top of your sketch. The first lines.
Check out this example
Where did you get this sketch from?
There is no nut icon in the new BlynkIoT app.
To get the auth token you will have to login to Blynk.console.
First update lib and browse through the examples provided in the arduino ide and select the edgent example to understand the full potential of the new platform.
