NODEMCU DHT servo reedswitch lcd
I’m needing help with getting my lcd to display a virtual pin from another nodemcu in my home. I will post the code from both sketches. I also am having trouble learning how to make the lcd do a page like effect one screen with temp+humidity and then go to door status then loop.
I have the dht11 working fine and displaying temp and rh.
I’m kind of stuck for now. I know my code is all over the place but most of it is copy pasted together.
//This is the bedroom mcu.
#include <Servo.h>
#include <Adafruit_Sensor.h>
#include <DHT_U.h>
#include <DHT.h>
#include <Wire.h>
#define DHTTYPE DHT11
#define DHTPIN 14
char auth[] = "lol";
char ssid[] = "NETGEAR";
char pass[] = "";
Servo servo;
DHT dht(DHTPIN, DHTTYPE);
LiquidCrystal_I2C lcd(0x27, 16, 2);
//Below is for servo neutral.
BLYNK_WRITE(V3) {
  servo.write(param.asInt());
  timer.setTimeout(2000L, ServoNeutral);  // In two seconds, Run the void ServoNeutral() routine.
void sendSensor()
  float h = dht.readHumidity();
  float t = dht.readTemperature(true);
  if (isnan(h) || isnan(t)) {
    Serial.println("DHT FAILURE");
    return;
  Blynk.virtualWrite(V20, h);
  Blynk.virtualWrite(V21, t);
//This is the pin I'm wanting to read. V1 is a open/closed value for my screen door.
BLYNK_WRITE(1)
  int pinValue = param.asInt();
void ServoNeutral() {
  servo.write(60);
  // Debug console Serial.begin(115200);
  Blynk.begin(auth, ssid, pass, IPAddress(10, 0, 0, 2), 8442);
  dht.begin();
  servo.attach(15); // 15 means D8 pin of ESP8266
//messy..
void backpack() {
  Wire.begin(D2, D1);
  lcd.begin();
  lcd.home();
  lcd.setCursor(1, 0);
  lcd.print(dht.readTemperature(true));
  delay (250);//How can this be replaced to refresh the updated values, this delay is messing up my loop
  lcd.setCursor(1,1);
  Blynk.run(); // You can inject your own code or combine it with other sketches.
  backpack();
this is the screendoor mcu’s sketch below.
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example runs directly on ESP8266 chip.
  Please be sure to select the right ESP8266 module
  in the Tools -> Board menu!
bool current = 0;
bool previous = 1;
char auth[] = "sameasothersketch";
char pass[] = "";
  Blynk.begin(auth, ssid, pass, IPAddress(10,0,0,2), 8442);
  pinMode(14, INPUT_PULLUP); //DOOR
void switchstate(){
  current = digitalRead(14);
  if (current != previous){
    previous = current;
    if (current == LOW)
              Blynk.virtualWrite(2, "1");
              Blynk.virtualWrite(1, "Closed.");
              Blynk.notify("Door Closed");
              Blynk.virtualWrite(2, "0");
              Blynk.virtualWrite(1, "Open.");
              Blynk.notify("Door Opened");
  switchstate();
How can I retrieve the state from a remote MCU? I have the blynk server on a pi so it is local. I have an eventor state that causes the door open state to trigger the servo on the lightswitch but I’m wanting to display the door state on a physical i2c lcd.
Try the Bridge Widget
Simple steps like set position, print data, wait for timer, clear screen, set new posistion, print new data, rinse and repeat.
My main thing now is I’m struggling with is to now output the bridge virtual pin variable to my lcd display.
I have only sent bridged data to Display Widgets, but the principle should be the same… although you will need to set cursor position “locally”… the following is UNtested…
On sending MCU (not showing the usual bridge setup):
bridge1.virtualWrite(vPin, "Data"); // Using vpin of receiving MCU
On receiving MCU:
BLYNK_WRITE(vPin) {
    Data = param.asStr();
    PLCD.setCursor(0, 2);
    PLCD.print(Data);
