I have NodeMCU which is connected to 16x2 LCD and a DHT11 sensor. My project is that the DHT11 data is displayed on LCD screen as well as on Blynk app and I have some trigers added into it for some special cases such as high temp etc. I have my local server setup.
After flashing the NodeMCU with my code, the NodeMCU connects to server then after few seconds disconnects and again connects. To debug the issue I connected my NodeMCU to my PC without sensor and LCD, but still the same problem was there, as i thought it could be low power problem. I tried the blink example, it worked fine.
The code of my project is:-
#include <DHT.h>
#include <Wire.h>
char auth[] = "XXXXXXXXXXXXXXXXXX";
char ssid[] = "ssid";
char pass[] = "password";
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
#define DHTPIN 8
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
pinMode(5, OUTPUT);
pinMode(4, OUTPUT);
if (isnan(h) || isnan(t)) {
digitalWrite(4, HIGH);
lcd.setCursor(0,0);
lcd.print(F("Failed to read !!"));
lcd.setCursor(0,1);
lcd.print(F(" ")); // Spaces to make 2nd line clear of lcd
return;
if (t > 30) {
digitalWrite(5, HIGH);
lcd.setCursor(13,1);
lcd.print(F(" * "));
else {
digitalWrite(5, LOW);
lcd.setCursor(14,1);
lcd.print(F(" "));
digitalWrite(4, LOW);
lcd.setCursor(0,0);
lcd.print(F("Humidity: "));
lcd.print(h, 0);
lcd.print(F(" %"));
lcd.setCursor(0,1);
lcd.print(F("Temp: "));
lcd.print(t, 2);
lcd.print(F(" C"));
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.begin(auth, ssid, pass, IPAddress(35,154,12,218), 8080); //Local server IP
lcd.begin(16,2);
dht.begin();
timer.setInterval(2000L, sendSensor);
At 115200 baud rate in serial monitor i get following message
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
