NodeMCU constantly disconnecting
Hey people I’m doing this project ( https://www.instructables.com/id/IOT-Pet-Feeder-Using-the-Blynk-Mobile-App-an-ESP82/) and it works fine as long as I dont disconnect my nodemcu from my computer. When I disconnect it starts connecting and disconnecting continuously from blynk, I dont think it’s a power supply issue! Please help me
I think it probably is a power supply issue. Maybe your power supply is inadequate, or you’re missing a Ground connection somewhere?
Try testing what the voltage is between the 5V and GND pins of the NodeMCU with the computer attached and then disconnected.
I’m using a lm7805 that is working fine. That’s really strange
The instructables project uses a LM2596 module.
could it be the problem? In my mind it doesn’t matter what regulator I use. But I’m a noob so idk
Well, look at it logically - you’ve taken a design that works, modified it and now it doesn’t work.
What does your multimeter say when you do the test I suggested earlier?
Double check your code even when arduino done compiling good , some time do not work
sorry about my English.
I tested with lm2596 and the problem persists. I dont know what else I can do
Does it work okay when you have nothing connected other than your 5v power supply?
