Nodemcu connection lost
Hi friends. I have a problem with nodemcu and widget map sketch, the sketch worked perfectly but the wifi connection is not stable. where is wrong ?
    /* BlynkifyGPS.ino for https://community.blynk.cc/t/arduino-or-nodemcu-gps-tracking-system-on-map-widget/15739
      Sketch for physical GPS device connected to a decent ESP
      In map widget set SHOW MY LOCATION to NO unless you also want Smartphone actual location in addition to GPS device + ESP
    #include <TinyGPS++.h>
    static const int RXPin = 4, TXPin = 3;
    static const uint32_t GPSBaud = 9600;
    TinyGPSPlus gps; // The TinyGPS++ object
    SoftwareSerial ss(RXPin, TXPin);  // The serial connection to the GPS device
    char auth[] = "6075f93a98734b3abddb3c3ba6babf08";
    char ssid[] = "MikroTik Home";
    char pass[] = "mypassword";
    char server[] = "192.168.1.104";
    //unsigned int move_index;         // moving index, to be used later
    unsigned int move_index = 1;       // fixed location for now
    bool simulation = false;           // set to true for simulation mode, else false. If IranHack is true this must be false
                                       // simulation location is in Egypt
    bool IranHack = false;             // set to true if GPS is faulty, else false. If simulation is true this must be false
    WidgetMap myMap(V5);
      Serial.println();
      ss.begin(GPSBaud);
      Blynk.begin(auth, ssid, pass, server);
      timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
    void checkGPS(){
      if (gps.charsProcessed() < 10)
        Serial.println(F("No GPS detected: check wiring."));
        Blynk.virtualWrite(V10, "GPS ERROR");  // Value Display widget set as PUSH frequency on V10
        Blynk.virtualWrite(V7, "--------");    // Value Display widget set as PUSH frequency on V7 LATITUDE
        Blynk.virtualWrite(V8, "--------");    // Value Display widget set as PUSH frequency on V8 LONGITUDE
      //delay(1000);  // NOT RECOMENDED
      if(simulation == true || IranHack == true)
        displayInfo();
        while (ss.available() > 0)  // sketch displays information every time a new sentence is correctly encoded.
          if (gps.encode(ss.read()))
            displayInfo();
    void displayInfo()
      if (gps.location.isValid() || simulation == true || IranHack == true)
        //move_index++;                        // moving index, maybe use later
        Blynk.virtualWrite(V10, "GPS OK");
        float latitude = (gps.location.lat());  // removed , 6 as it can't be used for creating the float
        float longitude = (gps.location.lng()); // removed , 6 as it can't be used for creating the float
        if(latitude == 0 && longitude == 0 )    // checking to see if the 2 floats variables are correct
          Blynk.virtualWrite(V10, "0,0");
        if(simulation == true)           // location in Egypt
          latitude  = 30.000123;       // also used for debugging
          longitude = 30.000987;       // also used for debugging
        if(IranHack == true)
          latitude  = 32.644824;
          longitude = 41.681746;
        Serial.print("LAT:  ");
        Serial.println(latitude, 6);  // float to x decimal places
        Serial.print("LONG: ");
        Serial.println(longitude, 6);
        Blynk.virtualWrite(V7, String(latitude, 6));
        Blynk.virtualWrite(V8, String(longitude, 6));
        myMap.location(move_index, latitude, longitude, "GPS_Location");
        Serial.print(F("INVALID"));
        Blynk.virtualWrite(V10, "GPS INVALID");
      Serial.println();
Maybe GPS data coming in too fast causing the while loop not to exit and therefore the blynk.run command to drop?
@ErfanDL After all this time, you are still not properly formatting your posted code. I have edited it for you… please look back at it to see the correct way. Thanks.
while loops are blocking commands, “while” the expression is false… I wonder if there could be potential for this to hold up the sketch long enough for disconnection?
