No Widgets at all
I don’t understand this. I’m a backer from Kickstarter but i don’t see widgets in the IOS blynk app??? I created a new project, and push the triangle. Waiting, see a quad icon and nothing else??
My login are xpixer @ …, here a sample token: d409b99xxxxxxxxxx
please help.
Hi, sorry it wasn’t clear enough.
1.Make sure you are in the Edit mode (you see a Play button triangle).
2. Tap anywhere on the screen - you’ll open the widget box.
3. After you add a widget, tap it to get to settings.
4. When you are ready — press Play
Also, never post your Auth Token and login information publicly, unless you want anyone to be able to take control of your hardware.
Thanks. now it works. The token are changed :smile:
