Newbie Widget Issues
I stumbled across this system a few days ago and it is just what I was looking for to access my Arduino projects remotely. I have a query regarding a couple of the widgets, I have the most up to date version of the IOS app, however I find that the “Labelled Value M” and “Labelled Value L” widgets will not display a value and they also use 400 energy but are listed as 200, so if you only have 200 left it will let you add widget then the app freezes and crashes. Has anyone else had this problem?
http://docs.blynk.cc/#widgets-displays-labeled-value you need to put /pin/.
This is a bug. Price should be 400.
Thank you for reporting we’ll investigate.
Thanks for getting back to me, I added /pin/ and now they display values, however the formatting options don’t seem to work. i.e. /pin.##/
.## is available only on Android now. Soon on iOS
