Newbie want to ask
Please help me. I try to upload example sketch from blynk (nodeMcu) but after done uploading to my nodeMcu8266, on Serial monitor show like this
“No yourWifiName found, reconnect after 1s”
Please help newbie
We recommend you start here and read the various documentation thoroughly… then it is easier for you to ask constructive questions and get constructive answers back.
http://help.blynk.cc/
You didn’t reference from where you got whatever example you are using (they are many, many, much, floating around out there).
However… unless your SSID is actually called yourWiFiName :stuck_out_tongue_winking_eye: then you will need to fill in the requisite data correctly in your sketch before uploading it.
