New to Blynk and having trouble with programming
I’m using the Sparktun EXP8266 Thing and I can’t seem to get the blynk script to load correctly.
When I try to load, I get the following
Archiving built core (caching) in: C:\Users\rjall\AppData\Local\Temp\arduino_cache_563290\core\core_esp8266_esp8266_thing_CpuFrequency_80,UploadSpeed_115200_b996282cc0bb5308041635deb0b64903.a
Sketch uses 232965 bytes (53%) of program storage space. Maximum is 434160 bytes.
Global variables use 32964 bytes (40%) of dynamic memory, leaving 48956 bytes for local variables. Maximum is 81920 bytes.
Uploading 237120 bytes from C:\Users\rjall\AppData\Local\Temp\arduino_build_844784/Thing1.ino.bin to flash at 0x00000000
… [ 34% ]
… [ 68% ]
… [ 100% ]
Invalid library found in C:\Users\rjall\Documents\Arduino\libraries\tools: C:\Users\rjall\Documents\Arduino\libraries\tools
I followed the directions on copying the tools folder so I’m not sure why I’m getting this error.
Any help is appreciated.
You need to move tools UP one directory.
They should be C:\Users\rjall\Documents\Arduino\tools
Stated clearly in Getting Started
Thank you. I think it programmed. Now to work out the link with my iPhone.
