New RTC changes - what am i missing?
i have 0.4.4 library and 0.21.7 local server, using the example sketch, this is my output:
ÿ[29437] Connecting to SSID
[33440] Connected to WiFi
[33440] IP: 192.168.0.112
[33440]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v0.4.4 on ESP8266
[33446] Connecting to 192.168.0.7
[33469] Ready (ping: 10ms).
Current time: 0:0:43 Current time: 0:0:53 Current time: 0:1:3 Current time: 0:1:13 Current time: 0:1:23 Current time: 0:1:33 Current time: 0:1:43 Current time: 0:1:53 Current time: 0:2:3 Current time: 0:2:13 Current time: 0:2:23 Current time: 0:2:33 Current time: 0:2:43 Current time: 0:2:53 Current time: 0:3:3 Current time: 0:3:13 Current time: 0:3:23 Current time: 0:3:33 Current time: 0:3:43 Current time: 0:3:53 Current time: 0:4:3 Current time: 0:4:13 Current time: 0:4:23 Current time: 0:4:33
see how it starts at 00:00 - that’s not the time here…
this sketch:
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  Blynk can provide your device with time data, like an RTC.
  Please note that the accuracy of this method is up to several seconds.
  App project setup:
    RTC widget (no pin required)
    Value Display M widget on V1
    Value Display M widget on V2
  WARNING :
  For this example you'll need SimpleTimer library:
    https://github.com/jfturcot/SimpleTimer
  And also this Time keeping library:
    https://github.com/PaulStoffregen/Time
  This code is based on an example from the Time library:
    https://github.com/PaulStoffregen/Time/blob/master/examples/TimeSerial/TimeSerial.ino
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "qwerty";
char ssid[] = "abc";
char pass[] = "123";
WidgetRTC rtc;
// Digital clock display of the time
void clockDisplay()
  // You can call hour(), minute(), ... at any time
  // Please see Time library examples for details
  Serial.print(currentTime);
  Serial.print(" ");
  // Send time to the App
  Blynk.virtualWrite(V24, currentTime);
  Blynk.begin(auth, ssid, pass, IPAddress(192, 168, 0, 7));
  // Begin synchronizing time
  rtc.begin();
  // Other Time library functions can be used, like:
  //   timeStatus(), setSyncInterval(interval)...
  // Read more: http://www.pjrc.com/teensy/td_libs_Time.html
  // Display digital clock every 10 seconds
  timer.setInterval(10000L, clockDisplay);
the 0.4.4 libraries:
I assume after moving the new libraries into this folder you closed the IDE, re-opened, then uploaded? One issue I had (and I have no idea how I managed to do this) was that I had two copies of some libraries and the IDE was pointing to the old location. Try searching your entire drive for another time.h file and see if anything else turns up.
Did you add the RTC widget in your dashboard???
[4269] Connected to WiFi
[4269] IP: xxx.xxx.xxx.xxx
[4269]
    ___  __          __
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.4 on Arduino
[4275] Connecting to xxx.xxx.xxx.xxx:xxxx
[4293] Ready (ping: 6ms).
[4306] Time sync: OK
Current time: 18:1:5 Current time: 18:1:15 Current time: 18:1:25 Current time: 18:1:35 Current time: 18:1:45 Current time: 18:1:55
Your code and “my” spanish time!
@Dave1829 if you are still struggling add the following before rtc.begin()
setSyncInterval(1);
and then in the clock loop
if(year() == 1970){
    setSyncInterval(1);
else{
  setSyncInterval(300000);  // sync every 5 minutes
  // virtualWrite time to the app etc
Yeah, i don’t get “Time sync OK”… Thanks for verification of the code @psoro
I’ll quadruple check the libraries, the complier was silent on libraries though @structure7 weird…
If it still fails I’ll use @Costas manual sync.
But it should work, therefore im thinking library most possible… I’m just checking I hadn’t overlooked something basic…
No worries @Dave1829, it should be a silly thing… Try to remove the RTC widget and add it again…
Yes tried that… :slight_smile:
Ok…last thing before to go to sleep…Android App version? 2.7.1?
@Dave1829,
Are you still struggling with the RTC?
My curiosity goes one step before me…:blush:
We had a android phone crash here yesterday… My ‘projects’ took a massive back step until we could retrieve the phone’s unbackedup data… I’m going to redo the local server with whatever the latest version is… It’s the only bit i haven’t redone… And my VNC is not working either, which is making it difficult!
Oh oh…It doesn’t sound good… Good luck Dave…
Kind regards!!
You basically stated the obvious…but was what was missing for me: RTC widget in dashboard!
I can say that for me, is working like a charm! Thanks guys.
was local server not updated properly (well, the autostart script to be precise),
at least i also fixed VNC :slight_smile:
