New programmable LED
here is my code which works perfectly. I press my on push button on my widget button, my relay changes position, and I have two LEDs which indicate the position, ON green, OFF red.
#define BLYNK_TEMPLATE_ID "xxxx"
#define BLYNK_DEVICE_NAME "xxxx"
#define BLYNK_FIRMWARE_VERSION        "0.1.0"
//#define BLYNK_DEBUG
#define APP_DEBUG
#include <Wire.h>
#include "BlynkEdgent.h"
// Set your LED and physical button pins here
const int relais1 = 14;
const int btn1 = 27;
const int ledV1 = 5;
const int ledR1 = 2;
int relais1Sate = LOW;
int btn1State = HIGH;
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
BLYNK_WRITE(V1) {
  relais1Sate = param.asInt();
  Serial.print("Widget Button V1 changed. Writing ");
  Serial.print(relais1Sate);
  Serial.print(" to Relay 1 and LED V1, and ");
  Serial.print(!relais1Sate);
  Serial.println(" to LED R1 ...");
  digitalWrite(relais1, !relais1Sate);
  digitalWrite(ledV1, !relais1Sate);
  digitalWrite(ledR1, relais1Sate);
void checkPhysicalButton1()
  if (digitalRead(btn1) == LOW)
    Serial.print("Location A, btn1 = ");
    Serial.print(digitalRead(btn1));
    Serial.print(" btn1State = ");
    Serial.println(btn1State);
    if (btn1State != LOW)
      Serial.print("Location B, btn1 = ");
      Serial.print(btn1);
      Serial.print(", btn1State = ");
      // Toggle LED state
      relais1Sate = !relais1Sate;
      Serial.print("Location C, writing ");
      Serial.println(" to Relay 1 ...");
      Serial.print("Location D, writing ");
      Serial.print(" to LED V1 and ");
      // Update Button Widget
      Serial.print("Location E, writing ");
      Serial.println(" to Button Widget on pin V1 ...");
      Blynk.virtualWrite(V1, relais1Sate);
      btn1State = LOW;
    btn1State = HIGH;
BLYNK_CONNECTED()
  Blynk.syncVirtual(V1);
void checkPhysicalButton1();
  delay(100);
  BlynkEdgent.begin();
  pinMode(relais1, OUTPUT);
  pinMode(btn1, INPUT_PULLUP);
  digitalWrite(relais1, relais1Sate);
  pinMode(ledV1, OUTPUT);
  pinMode(ledR1, OUTPUT);
  timer.setInterval(100L, checkPhysicalButton1);
  BlynkEdgent.run();
To save PINs on my esp32 I would like to replace my basic LEDs with ws2811 programmable LEDs. But I can not program, the LED lights up but does not change color do you have any idea.
#define BLYNK_TEMPLATE_ID "xxxxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxxxx"
#define APP_DEBUG
#include <Wire.h>
    #include <FastLED.h>
    #define NUM_LEDS 4
    #define DATA_PIN 13
     CRGB leds[NUM_LEDS];
BLYNK_WRITE(V1) {
      leds[1] = CRGB::Red,!relais1Sate;
      FastLED.show();
      leds[1] = CRGB::Green, relais1Sate;
     FastLED.show();
      Serial.print(btn1);
      // Toggle LED state
      FastLED.show();
     FastLED.show();
      btn1State = LOW;
    btn1State = HIGH;
BLYNK_CONNECTED()
  delay(100);
  FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
  BlynkEdgent.run();
does anyone have an idea for programming the addressable leds?
Change the number of LED’s to 6. I had the same issue a while ago. I had just 2 LED in the setup. So i had defined the same in the code. But that did not work until i changed it to 6 or more. Give it a try. I am not 100% sure that this will solve your problem. Or try changing the DATA pin or other WS2812 supporting library.
EDIT :
This should work. I am using this lib from a long time.
Thank you.
I am almost happy with the result.
I have programmed 1 push button in pin 27. Why do all my push buttons change the color of the LED?
#define BLYNK_TEMPLATE_ID "xxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxx"
#define APP_DEBUG
#include <Wire.h>
    #define NUM_LEDS 1
    #define DATA_PIN 13
BLYNK_WRITE(V1) {
      if (!relais1Sate){leds[0] = CRGB::Red;}
      if (relais1Sate){leds[0] = CRGB::Green ;}
     FastLED.show();
      Serial.print(btn1);
      // Toggle LED state
     FastLED.show();
      btn1State = LOW;
    btn1State = HIGH;
BLYNK_CONNECTED()
  delay(100);
  BlynkEdgent.run();
Check the wiring of the push buttons. I guess they all are connected in parallel :face_with_monocle:.
@Madhukesh you were right, it was a connection error
