In version 2.6.0 i cannot upload to the board, in 2.5.2 it is ok
Here the ouput in 2.6.0:
Executable segment sizes:
IROM : 226552 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26716 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 480 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24808 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 255000 bytes (51%) of program storage space. Maximum is 499696 bytes.
Global variables use 26540 bytes (32%) of dynamic memory, leaving 55380 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.7
Serial port COM5
Connecting........_
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 84:0d:8e:88:70:07
Uploading stub...
Running stub...
Stub running...
Manufacturer: 85
Device: 6014
Detected flash size: 1MB
Hard resetting via RTS pin...
esptool.py v2.7
Serial port COM5
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "C:\Users\hans\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.0/tools/upload.py", line 25, in <module>
esptool.main(fakeargs)
File "C:/Users/hans/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 2841, in main
esp.connect(args.before)
File "C:/Users/hans/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.0/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
_
the selected serial port _
does not exist or your board is not connected
And here the same scetch (Blink) in 2.5.2:
Sketch uses 257696 bytes (51%) of program storage space. Maximum is 499696 bytes.
Global variables use 26572 bytes (32%) of dynamic memory, leaving 55348 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.6
2.6
esptool.py v2.6
Serial port COM5
Connecting........_
Chip is ESP8266EX
Features: WiFi
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 1MB
Flash params set to 0x0320
Compressed 261856 bytes to 191265...
Writing at 0x00000000... (8 %)
Writing at 0x00004000... (16 %)
Writing at 0x00008000... (25 %)
Writing at 0x0000c000... (33 %)
Writing at 0x00010000... (41 %)
Writing at 0x00014000... (50 %)
Writing at 0x00018000... (58 %)
Writing at 0x0001c000... (66 %)
Writing at 0x00020000... (75 %)
Writing at 0x00024000... (83 %)
Writing at 0x00028000... (91 %)
Writing at 0x0002c000... (100 %)
Wrote 261856 bytes (191265 compressed) at 0x00000000 in 20.9 seconds (effective 100.4 kbit/s)...
Hash of data verified.
Leaving...
