New blynk server limited the virtual pins ?!
@Dmitriy Hi. is new local server limit the virtual pins ? it’s say max is 31 vpin
thanks
Doesn’t it depend on the device you select?
hmmm. yeah that’s right the arduino uno only support 31 Virtual pins !
If it’s just virtual pins I need for a project, I choose a raspberry pi 3 and you get 256 vpins :+1:
Some devices doesn’t have much memory - every virtual pin takes some space. So that’s why we added some limits per hardware (it was done 2 years ago I think). It is for good - the chance for crashing of the hardware is lower with limits.
Thanks for reply. But we can using multiple device with same token ID and more virtual pins
