New Blynk Library v0.5.1 is Released (important for local server owners)
sorry my muck up :wink:
As you can tell I’m getting confused between httpAPI and the direct comms from hardware sketch to local server.
So the blynk.config default port is now 80 ? (] 8442 will be dropped soon as you noted). Would i need to place 8080 in Blynk.config as per below or would the #define BLYNK_DEFAULT_PORT 8080 suffice ?
Blynk.config(auth_local_server, local_server, 8080);
You may not. It is up to you. You may not update the server and apps and you are fine.
Because new hardware port is 8080 and not 8442
I don’t know. You have to decide for yourself.
Should be fine.
Hi guys,
Port 80 isn’t going to work for me on my local server as it doubles as a web server.
Do I just need to do the following for the clients?
Or will I have to also update the sever to:
#hardware plain tcp/ip port
hardware.default.port=8080
Scratch that, I see that the server is already listening for hardware on 8080
#http, plain web sockets and plain hardware port
http.port=8080
@ThatGuy_ZA please read initial announcement again.
Gotcha, sorry, I was thrown off by this
actually what is this? any info / docs?
Allows the MIN / MAX setting to be changed from the sketch via Blynk.setProperty(vPin, “property”, value)
Although the Docs are not real clear on proper syntax :thinking: …
before asking, i tried ctrl+f setMin on the blynk docs page, but it found nothing, this is why i asked…
Not critiquing :wink: … I also couldn’t find it via searching. I just kept looking in the area I thought most relevant. For all I know, the docs haven’t been updated yet with this “new” command :stuck_out_tongue:
no stress :wink:
I think the documentation in general could use some touching up… needs to be technical in detail, but still understandable for the non-technical (use lots of crayons)… Hey @Pavlo I can work for peanuts… as long as those peanuts are branded “Wemos” :stuck_out_tongue_winking_eye:
https://github.com/blynkkk/blynkkk.github.io contains all the docs.
We’ll be really glad for some PRs for improvements!
Nice… I have never messed with GitHub forking before… already submitted a small change request :wink:
DM me the total number of :peanuts: you need :slight_smile:
I’m pretty sure we can make it work!
hi
Quick question. If I wanted my local server to listed on both 8080 and 80 would would I need to edit within server.properties file ?
hardware.default.port=8442
#http port MY note default is 8080]
http.port=8080
You can’t. You need to choose. Either 80 or 8080. hardware.default.port will be dropped in future.
I’ve just upgrading to v0.5.1 and currently working after adding port: 8080 to my sketch
Blynk.begin(auth, ssid, pass, blynk_server,8080);
But now my terminal showing following text upon restart:
1384, room 16
tail 8
chksum sys⸮⸮⸮⸮param error, use last saved param!
fortunately the system is working fine, should I worried about this?
@noersaleh please post your sketch. @vshymanskyy Do you know what that may be?
Is that from an ESP module? If so, it may be mem related. Google it…
