NEMA 17 stepper motor and drive A4988 does not work on app blynk
Both Blynk and stepper motors are a bit prima donna in their specific timing needs.
It can be done, but you may need to work some fancy coding… Here is an example I made using ESP8266/32 You should be able to change the libraries needed for the UNO/Ethernet and start experimenting, but as the UNO is quite a bit slower, the stepper may stutter more.
