Need help with project
i am using esp32
i have an error like the following:
exit status 0xc0000005
Compilation error: exit status 0xc0000005
sorry if my english is not understandable because it uses translate from google
Please
please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly. Triple backticks look like this: ```
Also explain the issue you are facing in detail.
Just a guess, I haven’t tested anything - do you need to include the wifi client?
#include <WiFiClient.h>
