through the application, there is no connection, and the port’s monitor writes like this
[0]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.7 on Arduino Uno
[89] Connecting...
[3189] Login timeout
[5189] Connecting...
[8270] Login timeout
[10270] Connecting...
[13351] Login timeout
[15351] Connecting...
[20432] Connecting...
[23513] Login timeout
[25513] Connecting...
I’m trying to connect via a smartphone, the indicator on the HC06 is lit that is connected, not in the app, there is no indication on the port monitor
Does the BLE widget in the app show your device and allow you to create a connection?
I’ve just noticed that you are using BTSerial for your debug messages…
As I said before, you can’t do this.
BTSerial is for the connection to the BT module ONLY
Serial is for debug messages using Serial.print
yes, I connected without any problems
yes, initially just Serial. print. what I wrote BT Serial thought this is the problem, but when Serial. print also does not work
