Need help with my NodeMCU V3
Untitled
this?
yes !
hmm so what should i do ?
9600 is ok
so I don’t know why you can’t see
hmm should i re flash my nodemcu again ?
yes try again, you have to flash it every time you modify your code
Its not working too :sob: can i use virtual pin in blynk like this ? To send noti
ehh
#include <ESP8266WiFi.h>;
must have semicolon at the end ?
no semicolon after include
alright @Blynk_Coeur i want to tell you that my coding works , buzzer led all works, im using this coding
const int gasPin=A0;
int gasValue=0;
const int buzpin=5;
const int threshold=100;
const int ledPin=4;
char auth[] = "e34ebc75567b4a098cc183acf7e84495";
char ssid[] = "babablacksheep";
char pass[] = "taikmu123";
  pinMode (gasPin,INPUT);
  pinMode (buzpin,OUTPUT);
  pinMode  (ledPin, OUTPUT);
  gasValue=analogRead(gasPin);
  Serial.println(gasValue);
  delay(200);
  if (gasValue>150)
    digitalWrite (2,HIGH);
    tone (buzpin,100);
    digitalWrite (ledPin, HIGH);
    delay(100);
    Blynk.virtualWrite(V4, gasValue);
    delay(100);
        digitalWrite (2,LOW);
        noTone(buzpin);
        digitalWrite (ledPin, LOW);
it send noti to my blynk app but it only send one noti only. after i try again to put gas to my gas sensor then it didnt send anymore hmm i dont know why
Hi @Ash_Twi,
Please, review the use of Blynktimer and change your code accordingly.
Your loop is Arduino style and you MUST learn and use Blynk style instead.
but i already used blynk style and i cant connect with my blynk app, hmm its okay now i will try again
I’m afraid using that loop you are far away from Blynk style…
Check the docs and learn about a nice loop using Blynk and the use of timers.
Don’t put any command inside void loop()-
it will cause reconnection to blynk server!
ok i change to blynk style , it is correct ? this sketch can connect to blynk app but my gas sensor didnt works so it cant send the noti
int gasValue=0;
const int buzpin=5;
const int ledPin=4;
char auth[] = "e34ebc75567b4a098cc183acf7";
char ssid[] = "xxxxxxxxxxx";
char pass[] = "xxxx";
  timer.setInterval(120000L, gas);  // check every 120s
void gas()
  delay(200);
  if (gasValue>150)
    delay(100);
    tone (buzpin,100);
    delay(100);
        noTone(buzpin);
yes this code is good
but why it cant detect the gas or it is slow to detect the gas because i put delay(100) ?
as you have a timer, you don’t need delay()
sorry I have not gas sensor, I can’t help you :face_with_raised_eyebrow:
Reduce your interval to 1000L for instance and check results.
Delete this delay
It looks like Blynk style… :wink:
