Need help with my NodeMCU V3
Hi, Im having problem with my nodemcu. Im upload all coding of gas sensor into my nodemcu then it got error “an error occured while uploading the sketch”
I use port 4
board Generic ESP8266 Module
(It is correct board for mylilon nodemcu v3 ?)
and this is my coding
#include <ESP8266WiFi.h>;
const int gasPin=A0;
int gasValue=0;
const int buzpin=5;
const int threshold=100;
const int ledPin=6;
  pinMode (gasPin,INPUT);
  pinMode (buzpin,OUTPUT);
  pinMode  (ledPin, OUTPUT);
  gasValue=analogRead(gasPin);
  Serial.println(gasValue);
  delay(500);
  if (gasValue>150)
    digitalWrite (2,HIGH);
    tone (buzpin,100);
    digitalWrite (ledPin, HIGH);
    delay(100);
      else if (gasValue<150)
        digitalWrite (2,LOW);
        noTone(buzpin);
        digitalWrite (ledPin, LOW);
How is this question related to Blynk?
Possibly the nodemcu is not set to programming mode (“Flash” button)?
If i didnt success yet with this coding so how can i connect with blynk hmm , ok let me try it
Try disconnecting all the external connections from your NodeMCU and re-flashing it again.
When you do re-connect your external devices, be aware that the GPIO numbers used in the code (GPIO 5 for your buzzer and 6 for your LED) are not the pins marked D5 and D6 on the board.
GPIO 5 is marked D1
GPIO 6 is not available on the NodeMCU anyway, so once you get your code uploaded it will probably crash anyway as you’re trying to do write operations to a reserved GPIO.
it is a mistake
you have to choose nodemecu 1.0
How to re flashing my nodemcu ,can i just press that flash button?
So gpio 5 is d1 in my nodemcu
Gpio 6 can i put on d2 ?
Ohh :ok_hand:Thank you
look that
ARDUINO NODEMCU
16 DO
5 D1
4 D2
0 D3
2 D4
14 D5
12 D6
13 D7
15 D8
3 D9
1 D10
Wahh thank youu , about the re flash my nodemcu , can i just press the button ‘flash’ on the nodemcu
if you want to upload your sketch , flash button is not need on the nodemcu
But pete said “Try disconnecting all the external connections from your NodeMCU and re-flashing it again” because i get an error while trying to upload my sketch
let me see your issue when you upload
The flash button on the NodeMCU doesn’t normally need to be used when reflashing. I think it’s only there so that if you manage to get into a reset loop where the code that you have previously uploaded is preventing you from re-flashing with new code, you can use the Flash button to put the device into a state where it doesn’t execute the uploaded code.
To use the Flash button, disconnect the power, then press and hold the Flash button whilst reconnecting the power, then release the button and upload your code.
I don’t think there’s actually any significant differences between the Generic ESP and NodeMCU v1.0 Board types, provided you choose nodemcu as your reset type when using the generic board.
You need to change your code so that you define your LED pin as something other than “6” and connect the LED to the appropriate pin. I’d suggest changing the code to use GPIO4, in which case the LED should be connected to D2.
@Blynk_Coeur , @PeteKnight ok success uploading and my led , gas sensor also buzzer also works thank you so muchhhh , now i want to include blynk to my coding.
my project is ,when the gas sensor detect gas then it will send noti to blynk so can i use this coding ?
    Follow us:                  http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  You’ll need:
   - Blynk App (download from AppStore or Google Play)
   - ESP8266 board
  started. Think of them as LEGO bricks  and combine them as you wish.
  example.
char auth[] = "e34ebc75567b4a098cc183acf7e84495";
char pass[] = "YourPassword";
  // to avoid delay() function!
const int gasPin = A0;
int gasValue = 0;
const int buzpin = 5;
const int threshold = 100;
const int ledPin = 6;
char auth[] = "e34ebc75567b4a098cc1xxxxxxxx";
  pinMode (gasPin, INPUT);
  pinMode (buzpin, OUTPUT);
  timer.setInterval(120000L, gas);  // check every 120s
void gas()
  gasValue = analogRead(gasPin);
  delay(500);
  if (gasValue > 150)
    digitalWrite (2, HIGH);
    tone (buzpin, 100);
    delay(100);
  else if (gasValue < 150)
    digitalWrite (2, LOW);
    noTone(buzpin);
i copy all of this coding and put my own auth,ssid and pass but my buzzer,led doesnt work and why my serial monitor all blank?
and
should “BlynkSimpleEsp8266.h” become red color as the other #include ? because mine is black
mine is black too
did you select the good com speed ?
where to know the com speed?
