So, I made a controller with Arduino Mega 2560, ENC28j60 Ethernet Shield, and 8 relay module.
I also have sensors in my rooms that send to Mega temperature (Wemos D1 with BNP180).
My problem is, when the controller changes from heating mode to a normal mode, relays get to HIGH if actualTemp is greater than setTemp - hysteresis. How can I make it to stay relay at LOW after a change to normal until actualTemp value gets to SetTemp.
void heating(){
for(int i=0; i<4; i++) {
digitalWrite(r[i], LOW);
p[i] = 1;
digitalWrite(r[7], LOW);
digitalWrite(r[6], LOW);
led1.on();
led2.on();
mode = 1;
heat = 1;
void normal(){
if(heat == 1){
digitalWrite(r[i], HIGH);
p[i] = 0;
led1.on();
digitalWrite(r[6], HIGH);
led2.off();
led1.off();
heat = 0;
if(heat == 0){
if(actualTemp[i] < setTemp[i] - histeresis){
p[i] = 1;
if(actualTemp[i] >= setTemp[i]){
p[i] = 0;
if(p[0] == 1 || p[1] == 1 || p[2] == 1 || p[3] == 1){
led1.on();
}else{
digitalWrite(r[7], HIGH);
led1.off();
led2.on();
mode = 2;
And of course, there’s all code:
#include <UIPEthernet.h>
#include <BlynkSimpleUIPEthernet.h>
#include <TimeLib.h>
#include <EEPROM.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
WidgetLED led1(V30);
WidgetLED led2(V31);
WidgetLED ledr0(V32);
WidgetLED ledr1(V33);
WidgetLED ledr2(V34);
WidgetLED ledr3(V35);
WidgetTerminal terminal(V40);
char auth[] = "123123123";
const int r[8] = {30, 31, 32, 33, 34, 35, 36, 37};
const float histeresis = 2.00f;
int p[4] = {0};
float setTemp[4] = {0.00f};
float actualTemp[4] = {1.00f};
float H = 0.00f;
float M = 0.00f;
float T = 0.00f;
float m = 0.00f;
float t[4] = {0.00f};
int mode, stopHeat;
int heat = 1;
BLYNK_CONNECTED() {
rtc.begin();
void setup(){
Blynk.begin(auth);
EEPROM.get(0, t[0]);
EEPROM.get(10, t[1]);
EEPROM.get(20, t[2]);
EEPROM.get(30, t[3]);
Serial.println("Witam! Zaczynam działanie ;)");
Serial.println("t0: " + String(t[0]));
Serial.println("t1: " + String(t[1]));
Serial.println("t2: " + String(t[2]));
Serial.println("t3: " + String(t[3]));
for(int i = 30; i < 38; i++){
pinMode(i, OUTPUT);
digitalWrite(i, LOW);
delay(200);
digitalWrite(i, HIGH);
timer.setInterval(60000L, clockDisplay);
led1.off();
led2.off();
setSyncInterval(10 * 60);
void loop(){
if(Blynk.connected()) {
Blynk.connect(3333);
m = minute();
H = hour();
M = m/60;
T = H + M;
if(T >= t[0] && T < (t[0] + 1.00) || T >= t[2] && T < (t[2] + 1.00))heating();
if(T >= (t[0] + 1.00) && T < t[1] || T >= (t[2] + 1.00) && T < t[3])normal();
if(T >= t[1] && T < t[2] || T >= t[3] && T < 24.00 || T >= 0.00 && T < t[0])pause();
if(p[0] == 1){ledr0.on();}
if(p[1] == 1){ledr1.on();}
if(p[2] == 1){ledr2.on();}
if(p[3] == 1){ledr3.on();}
if(p[0] == 0){ledr0.off();}
if(p[1] == 0){ledr1.off();}
if(p[2] == 0){ledr2.off();}
if(p[3] == 0){ledr3.off();}
void heating(){
p[i] = 1;
led1.on();
led2.on();
mode = 1;
heat = 1;
void normal(){
if(heat == 1){
p[i] = 0;
led1.on();
led2.off();
led1.off();
heat = 0;
if(heat == 0){
p[i] = 1;
p[i] = 0;
led1.on();
}else{
led1.off();
led2.on();
mode = 2;
void pause(){
p[i] = 0;
led1.off();
led2.off();
mode = 3;
void clockDisplay() {
if(mode == 1){
Serial.println(String(hour()) + ":" + String(minute()) + " grzanie " + String(T));
terminal.println(String(hour()) + ":" + String(minute()) + " grzanie " + String(T));
if(mode == 2){
Serial.println(String(hour()) + ":" + String(minute()) + " normalny " + String(T));
terminal.println(String(hour()) + ":" + String(minute()) + " normalny " + String(T));
if(mode == 3){
Serial.println(String(hour()) + ":" + String(minute()) + " przerwa " + String(T));
terminal.println(String(hour()) + ":" + String(minute()) + " przerwa " + String(T));
BLYNK_WRITE(V20){
float x = param.asFloat();
t[0] = x;
EEPROM.put(0, t[0]);
Serial.println(t[0]);
terminal.println(t[0]);
BLYNK_WRITE(V21){
t[1] = x;
EEPROM.put(10, t[1]);
Serial.println(t[1]);
terminal.println(t[1]);
BLYNK_WRITE(V22){
t[2] = x;
EEPROM.put(20, t[2]);
Serial.println(t[2]);
terminal.println(t[2]);
BLYNK_WRITE(V23){
t[3] = x;
EEPROM.put(30, t[3]);
Serial.println(t[3]);
terminal.println(t[3]);
//sensor0
BLYNK_WRITE(V10) {
float x = param[0].asFloat();
float y = param[1].asFloat();
setTemp[0] = x;
actualTemp[0] = y;
//sensor1
BLYNK_WRITE(V11) {
setTemp[1] = x;
actualTemp[1] = y;
//sensor2
BLYNK_WRITE(V12) {
setTemp[2] = x;
actualTemp[2] = y;
//sensor3
BLYNK_WRITE(V13) {
setTemp[3] = x;
actualTemp[3] = y;
void(* resetFunc) (void) = 0;
BLYNK_WRITE(V100) // Reset
if (param.asInt()==1) {
delay(100);
resetFunc();
Sorry for not having great English, and thanks for all suggestions.
