Need help with load cell
Hello everyone!
I am building a monitor system for my diploma thesis using IoT. I hooked up an Arduino with a DHT22, IR sensor and a load cell. Blynk shows up everything apart from the Load Cell. The weighing works find through serial, but when I try to connect it with Blynk it doesn’t show up anything. Here’s my code!
#include <Ethernet.h>
#include "HX711.h"
char auth[] = "9e266492de724588a5a85c4f394b966e";
#define W5100_CS  10
#define DHTTYPE DHT22
#define DHTPIN 6
#define DOUT  7
#define CLK  8
#define calibration_factor -100000
DHT dht(DHTPIN, DHTTYPE);
HX711 scale(DOUT, CLK);
void sendSensor()
  float h = dht.readHumidity();
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  if( h>60)
    Blynk.notify("Warning! Increased humidity!");
  if( t>25)
    Blynk.notify("Warning! Increased temperature!");
void sendIR()
  int detect = digitalRead(9);
   if(detect==LOW){
    Blynk.virtualWrite(V3,"Motion");
  else{
   Blynk.virtualWrite(V3,"OK");
void sendloadcell()
  Blynk.virtualWrite(V1,scale.get_units(),1);
  Blynk.begin(auth);
  dht.begin();
  pinMode(9, INPUT);
  scale.set_scale(calibration_factor);
  scale.tare();
  timer.setInterval(1000L, sendIR);
  timer.setInterval(1000L, sendloadcell);
Replace with Blynk.virtualWrite(V1,String(scale.get_units(),1));
