I am trying to set up a wifi shield with my project. I have a basic setup with Arduino Uno (SparkFun Red Board) and have attached SparkFun esp8266 wifi shield using stacked headers. I am using:
- Example code under Fille->Examples->Blynk->Boards_WiFi->ESP8266_Shield
- Blynk Libray version 0.6.1
The issue is I am not able to compile this with the right board; this should be flashing on Arduino UNO board and when I select that, I get the message: “Error compiling for board Arduino UNO”. I tried several other boards, but with no success. Any suggestions?
Here is the sample code I used (as reference):
@sudhakar.bhat please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Sorry Pete. Hope this works:
http://twitter.com/blynk_app
This example shows how to use ESP8266 Shield (with AT commands)
to connect your project to Blynk.
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
#include <ESP8266_Lib.h>
char auth[] = "5SWSReGDY9EA-VRToSQn6WnuCguirDvx";
char ssid[] = "xxx";
char pass[] = "yyy";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
No.
I gave you triple backticks to copy paste, why not use them?
Any reason why you didn’t edit your original post as I requested?
Pete - I didn’t realize I could edit my earlier post until later… Now I know:)
Anybody have any clues on what board to select to make sure it compiles? Appreciate any help here?
