I never think that way. After all… how could a cart be invented if one wouldn’t invent a wheel first?
I wonder if programmers or developers ever look on the forum, i think 189 post can really get some interest and curiosity from them, maybe they can jump in and say something smart,or stupid LOL
or have some solutions
next invention would be ESP64 lol:)
you will hear mostly silence But that “music” isn’t that bad, as long as a constant progress is noted.
Already 3 cores! They add 2 more, and call it… a “pentium”?.
No updates excpet I tried uploading through arduino ESP8266 ide blynk code directly on esp-01 and it works, with connecting speed like light speed!!!
Currently investigating i2c communication methods between ESP and arduino and it seems it is possible that 8266 can act and communicate as a Slave …i will report back…
The ESP-01 will support i2C with SDA ↔ GPIO0 & SCK ← ?GPIO2
But with EasyTransfer, you will need the ESP-01 to be the master requesting data from the Arduino.
I think this is a good example? I haven’t dug into it heavily yet… but soon.
https://github.com/klucsik/esp8266-and-arduino-mega-i2c-comm
You mean ESP as master or Arduino as slave rather than ESP as slave, right?
This sounds like one of those conversations you have with your kids when you’re trying to ge them to try a new food…
@Costas “Come on, try one of these Wemos D1 Minis, you’ll really like it, and it’s good for you”
@Nixon “No, I don’t like it”
@Costas “But you’ve never tried it”
@Nixon “I know, but I won’t like it”
Some time later…
@Nixon “These Wemo D1 Minis are great. I hate those Arduinos and silly little ESP-01s. Why did you keep making me use them, and why didn’t you tell me about the Wemos earlier”
@PeteKnight I’m not sure @Nixon has come over from the dark side yet as he refers to '01’s, not Mini’s in the last post. But I feel @Nixon is starting to see the light even if a little confused with master and slave.
Although I’m almost sure @Nixon is currently working hard on proper comm protocol to make Atmega MCU as a SLAVE to ESP8266, I decided to give a try his method of connection treating in ESP “Shield” mode. For this purpose I took his code and slightly modified it for my needs without loosing it’s working principle (I think…). And IT WORKS on my local server! No need to comment it further than that… And here is the modified code:
The setup():
display1.setBrightness(4);
display2.setBrightness(4);
display1.setSegments (SEG_DASH);
display2.setSegments (SEG_DASH);
pinMode (ESP_RST, OUTPUT);
pinMode (BUILTIN_LED, OUTPUT);
digitalWrite (ESP_RST, HIGH);
digitalWrite (BUILTIN_LED, HIGH);
//Setup the BME280
Sensor.settings.commInterface = I2C_MODE;
Sensor.settings.I2CAddress = 0x76;
Sensor.settings.runMode = 3; //Normal mode
Sensor.settings.tStandby = 3;
Sensor.settings.filter = 4;
Sensor.settings.tempOverSample = 3;
Sensor.settings.pressOverSample = 2;
Sensor.settings.humidOverSample = 3;
if (!Sensor.begin()) {
display1.setSegments(SEG_ERR);
display2.setSegments(SEG_ERR);
while (1);
//init timers
timer.setInterval(60000L, SendData);
timer.setInterval(6000L, updateDisplay);
The connection handling:
bool CheckConnection() {
if (Blynk.connected()) return true;
else {
display1.setSegments(SEG_CONN);
display2.setSegments(SEG_WAIT);
//Blynk.disconnect();
digitalWrite (ESP_RST, LOW);
delay(100);
delay(3000);
wifi.setDHCP(1, 1, 1); //Enable dhcp in station mode and save in flash of esp8266
Blynk.config(wifi, auth, server_ip, port);
if (Blynk.connectWiFi(ssid, pass)) {
Blynk.connect();
if (!Blynk.connected()) {
delay(1500);
return false;
else {
display2.setSegments(SEG_GOOD);
delay(1500);
return true;
And the loop:
if (CheckConnection()) Blynk.run();
@marvin7 Interesting…
I wonder if something has changed in recent Blynk libraries?
Because in the past when I tried it, I don’t recall being able to compile Blynk.config()
or wifi.*()
commands if using #include <BlynkSimpleShieldEsp8266.h>
But hey, it seems to compile now, so onto further experimenting
Yes @Gunner, it is working really nice with this code. I just changed it back to static IP and just left the connection handling as above.
One note: I included modification in BlynkSimpleShieldEsp8266.h
as pointed by @Nixon and now it works even better! (the reconnect is handled better)
EDIT: And now it is working with AT 2.0.0, where previously it usually failed! That is interesting… But nice!
ооо да))) esp возможно и хорошоя плата, но документации под нее очень мало…
простейшие задачи, которые с легкостью работают на атмега
esp требует много часов изучения и не всегда удачно
я думаю Никсон это понял и решил оставаться на старой и проверенной машине)))
я в такой же ситуации)))
решил перенести проек с нано на esp…
с Вашей помощью подключил max6675
а oled 128х32 - просто проблема))))
много библиотек - и не одна не работает)))
изготавливаю простейшие приборы мониторинга, температура или скорость ветра или напряжение
128х64 просто не нужен
поэтому я тоже на этой ветке пытаюсь найти пример нормальной работы нано и esp for blynk
oh yeah))) esp maybe a good board, but there is very little documentation for it …
The simplest tasks that work with ease at atmega
esp requires many hours of study and is not always successful
I think Nixon understood this and decided to stay on the old and tested car)))
I am in the same situation)))
decided to move the project from nano to esp …
with your help connected max6675
and oled 128x32 - just a problem))))
many libraries - and not one does not work)))
I make the simplest monitoring devices, temperature or wind speed or voltage
128h64 just do not need it
so I’m also trying to find an example of the normal operation of nano and esp for blynk on this branch
Well… After modifying BlynkSimpleShieldEsp8266.h
(for those who do not want to search here’s the link to modified file: BlynkSimpleShieldEsp8266.h
AND using connection handling as in my post from March, 18th I never had to reset the MCU manually (well, except twice, when flashed after further mods).
One note however: I rejected BlynkTimer and just using simple time countdown (I had some issues with more than one time interval) and introduced watchdog to make the device as “standalone” and user-free as possible. Aside from that - It still works. So now the loop looks like that:
if (CheckConnection()) {
if (millis() - previous_time[1] > timer60) {
previous_time[1] = millis();
SendData();
if (millis() - previous_time[0] > timer6) {
previous_time[0] = millis();
updateDisplay();
wdt_reset();
для моих задач этого много)))
я делаю простейший прибор
на nano он работает идеально
а nodmcu испортил мне все нервы))))
начиная от max6675
а сейчас и oled 128x32 )))
самое нехорошее - спаял уже прототип))) подключил датчики и реле)))
а экран никак)))
сам над собой смеюсь)))))
for my tasks this much)))
I make the simplest device
on nano it works perfectly
and nodmcu spoiled all my nerves))))
starting from max6675
but now oled 128x32)))
most bad - soldered already prototype))) connected sensors and relays)))
and the screen does not)))
I’m laughing at myself)))))
Well, my only experience with displays and ESP is the 84x48 NOKIA display based on PCD8544 controller. This one is working without issues “just like that”
старая школа)))
великоват он для меня
буду искать рабочую библиотеку
old school)))
he is too big for me
I will look for a working library
скурил я килограмм бумаги ( английский мой гамно)
есть библиотека правельная)))
I scooted a kilogram of paper (my English gamna)
there is a library right)))
может пригодиться и вам)))
сомневаюсь))) вы намного мощнее в теме)))
но иногда школьники имеют информацию полезную)))
may come in handy to you)))
I doubt))) you are much more powerful in the subject)))
but sometimes schoolchildren have useful information)))
Actually i’am back from the dark side,
I’am glad Marvin that you find my code useful but for me there is no coming back on AT commands again no Way.
I made programmer for esp8266 from arduino UNO did not want to wait Chinese FTDI programmer.
https://community.blynk.cc/uploads/default/original/2X/9/9ca5f76d7615d271c717a603b98d9dd359312635.png
for info : (resistors are not neded)
And yes long time ago in old esp8266 core was implementation for 8266 to be a slave,as i was telling month ago,who reads code can find that information, for example here:
but now is disabled, i tried to patch everything and get working version where Esp8266 is slave, i wasn’t satisfied,how it was working and i stick to Esp8266 as a master.
Easy Transfer library:
did not work as expected and in 2 directions, so i write my routines for communication over i2c based on Nick Gammon informations
http://www.gammon.com.au/i2c
but with using structures and unions for easy converting packets of data into values.
And yes,by the way, i found big bug in Arduino Ide compiler for Esp8266, regarded to wrong representation of sizeof structure:
But i solve that and made all working.
Also for ugly start smart implemented very good almost perfect WiFiManager library
so after all i’am pretty satisfied with all, but i notice when i put all together, in testing that Esp8266 chrashes sometimes when internet is low on signal,or when router starts to act strangely and gets disconnected for a while and blink trys to connect, Esp chrashes,but i will find and test more efficient way to manage blynk connection…
That is update…for now…and yes you guys were rigt all this was like like one of those conversations you have with your kids when you’re trying to ge them to try a new food…
