Hi!
Need help with code for my modified 3 axis camera slider based on this project: https://www.youtube.com/watch?v=kdMYD4DvWus
Problem is that I want to make a “Loop Mode” button with “Loop Mode ON and OFF” in Blynk that repeat all stepper movements forever and when press the button to “OFF” mode its stops the motors.
Now its loop forever but don’t react when I turn the button “Off”. (Check “loopMode V21” in code and void sliderStart()).
Can somebody please help me?
Hardware: Arduino UNO with CNC Shield v3 and HM10 bluetooth: 3 x Nema 17.
#include <AccelStepper.h>
#include <MultiStepper.h>
#define EnableMotors 8
// Define the stepper motors and the pins the will use
AccelStepper stepper1(1, 2, 5); // (Type:driver, STEP, DIR)
AccelStepper stepper2(1, 3, 6);
AccelStepper stepper3(1, 4, 7);
MultiStepper StepperControl; // Create instance of MultiStepper
long gotoposition[3]; // An array to store the In or Out position for each stepper motor
int currentSpeed = 1000;
int ProgrammSpeed = 3000;
int loopMode = 0;
int stopStepper = 0;
long XPointA = 0;
long YPointA = 0;
long ZPointA = 0;
long XPointB = 0;
long YPointB = 0;
long ZPointB = 0;
long XPointC = 0;
long YPointC = 0;
long ZPointC = 0;
long XPointD = 0;
long YPointD = 0;
long ZPointD = 0;
long XPointH = 0;
long YPointH = 0;
long ZPointH = 0;
char auth[] = "3y7tSgGXJhoSzbKl7HjjQgQo2aW-uTin";
WidgetLED led(V28);
WidgetLED led2(V29);
WidgetLED led3(V30);
WidgetLED led4(V31);
SoftwareSerial SerialBLE(10, 11); // RX, TX
BLYNK_WRITE(V4)
int pinAValue = param.asInt(); // assigning incoming value from pin V4 to a variable
if(pinAValue==1){
XPointA = stepper1.currentPosition(); // Set the IN position for steppers 1
YPointA = stepper2.currentPosition(); // Set the IN position for steppers 2
ZPointA = stepper3.currentPosition(); // Set the IN position for steppers 3
Blynk.virtualWrite(V4, HIGH);
Blynk.virtualWrite(V18, XPointA);
Blynk.virtualWrite(V19, YPointA);
Blynk.virtualWrite(V20, ZPointA);
XPointA = 0; // Set the IN position for steppers 1
YPointA = 0; // Set the IN position for steppers 2
ZPointA = 0; // Set the IN position for steppers 3
BLYNK_WRITE(V5)
int pinBValue = param.asInt(); // assigning incoming value from pin V5 to a variable
if(pinBValue==1){
XPointB = stepper1.currentPosition(); // Set the IN position for steppers 1
YPointB = stepper2.currentPosition(); // Set the IN position for steppers 2
ZPointB = stepper3.currentPosition(); // Set the IN position for steppers 3
Blynk.virtualWrite(V5, HIGH);
Blynk.virtualWrite(V18, XPointB);
Blynk.virtualWrite(V19, YPointB);
Blynk.virtualWrite(V20, ZPointB);
XPointB = 0; // Set the IN position for steppers 1
YPointB = 0; // Set the IN position for steppers 2
ZPointB = 0; // Set the IN position for steppers 3
Blynk.virtualWrite(V5, LOW);
BLYNK_WRITE(V6)
int pinCValue = param.asInt(); // assigning incoming value from pin V6 to a variable
if(pinCValue==1){
XPointC = stepper1.currentPosition(); // Set the IN position for steppers 1
YPointC = stepper2.currentPosition(); // Set the IN position for steppers 2
ZPointC = stepper3.currentPosition(); // Set the IN position for steppers 3
Blynk.virtualWrite(V6, HIGH);
Blynk.virtualWrite(V18, XPointC);
Blynk.virtualWrite(V19, YPointC);
Blynk.virtualWrite(V20, ZPointC);
XPointC = 0; // Set the IN position for steppers 1
YPointC = 0; // Set the IN position for steppers 2
ZPointC = 0; // Set the IN position for steppers 3
Blynk.virtualWrite(V6, LOW);
BLYNK_WRITE(V7)
int pinDValue = param.asInt(); // assigning incoming value from pin V7 to a variable
if(pinDValue==1){
XPointD = stepper1.currentPosition(); // Set the IN position for steppers 1
YPointD = stepper2.currentPosition(); // Set the IN position for steppers 2
ZPointD = stepper3.currentPosition(); // Set the IN position for steppers 3
Blynk.virtualWrite(V7, HIGH);
Blynk.virtualWrite(V18, XPointD);
Blynk.virtualWrite(V19, YPointD);
Blynk.virtualWrite(V20, ZPointD);
XPointD = 0; // Set the IN position for steppers 1
YPointD = 0; // Set the IN position for steppers 2
ZPointD = 0; // Set the IN position for steppers 3
Blynk.virtualWrite(V7, LOW);
BLYNK_WRITE(V9)
int pinHValue = param.asInt(); // assigning incoming value from pin V9 to a variable
if(pinHValue==1){
stepper1.setCurrentPosition(0); // Set the IN position for steppers 1
stepper2.setCurrentPosition(0); // Set the IN position for steppers 2
stepper3.setCurrentPosition(0); // Set the IN position for steppers 3
Blynk.virtualWrite(V9, HIGH);
BLYNK_WRITE(V8)
int pinGHValue = param.asInt(); // assigning incoming value from pin V8 to a variable
if(pinGHValue==1){
Blynk.virtualWrite(V8, HIGH);
gotoposition[0] = 0;
gotoposition[1] = 0;
gotoposition[2] = 0;
stepper1.setMaxSpeed(4000);
stepper2.setMaxSpeed(4000);
stepper3.setMaxSpeed(4000);
StepperControl.moveTo(gotoposition); // Calculates the required speed for all motors
StepperControl.runSpeedToPosition(); // Blocks until all are in position
stepper1.setSpeed(0);
stepper2.setSpeed(0);
stepper3.setSpeed(0);
stepper1.setMaxSpeed(6000);
stepper2.setMaxSpeed(6000);
stepper3.setMaxSpeed(6000);
Blynk.virtualWrite(V18, gotoposition[0]);
Blynk.virtualWrite(V19, gotoposition[1]);
Blynk.virtualWrite(V20, gotoposition[2]);
Blynk.virtualWrite(V8, LOW);
BLYNK_WRITE(V10)
int pinSValue = param.asInt(); // assigning incoming value from pin V10 to a variable
if(pinSValue==1) {
Blynk.virtualWrite(V10, HIGH);
SliderStart(); }
else {
Blynk.virtualWrite(V10, LOW);
BLYNK_WRITE(V11)
int pinSAValue = param.asInt(); // assigning incoming value from pin V11 to a variable
if(pinSAValue==1) {
Blynk.virtualWrite(V11, HIGH);
GoPos01();
Blynk.virtualWrite(V11, LOW);
BLYNK_WRITE(V12)
int pinSBValue = param.asInt(); // assigning incoming value from pin V12 to a variable
if(pinSBValue==1) {
Blynk.virtualWrite(V12, HIGH);
GoPos02();
Blynk.virtualWrite(V12,LOW);
BLYNK_WRITE(V13)
int pinSCValue = param.asInt(); // assigning incoming value from pin V13 to a variable
if(pinSCValue==1) {
Blynk.virtualWrite(V13, HIGH);
GoPos03();
Blynk.virtualWrite(V13, LOW);
BLYNK_WRITE(V14)
int pinSDValue = param.asInt(); // assigning incoming value from pin V14 to a variable
if(pinSDValue==1) {
Blynk.virtualWrite(V14, HIGH);
GoPos04();
Blynk.virtualWrite(V14, LOW);
BLYNK_WRITE(V1)
currentSpeed = pinValue;
currentSpeed = map(currentSpeed, 0, 100, 0, 2000);
BLYNK_WRITE(V15)
int pinValue = param.asInt(); // assigning incoming value from pin V15 to a variable
ProgrammSpeed = pinValue;
ProgrammSpeed = map(ProgrammSpeed, 0, 100, 0, 6000);
BLYNK_WRITE(V0)
int sliderValue = param.asInt(); // assigning incoming value from pin V0 to a variable
// Slider potentiometer
// If potentiometer is turned left, move slider left
if (sliderValue > 600) {
sliderValue = map(sliderValue, 600, 1024, 0, 6000);
stepper1.setSpeed(sliderValue); // Increase speed as turning
// If potentiometer is turned right, move slider right
else if (sliderValue < 400 ) {
sliderValue = map(sliderValue, 400, 0, 0, 6000);
stepper1.setSpeed(-sliderValue); // Increase speed as turning
// If potentiometer in middle, no movement
else {
BLYNK_WRITE(V3) {
int x = param[0].asInt();
int y = param[1].asInt();
// Joystick X - Pan movement
// if Joystick is moved left, move stepper 2 or pan to left
if (x > 60) {
x = map(x, 60, 100, 0, currentSpeed);
stepper2.setSpeed(-x);
// if Joystick is moved right, move stepper 2 or pan to right
else if (x < 40) {
x = map(x, 40, 0, 0, currentSpeed);
stepper2.setSpeed(x);
// if Joystick stays in middle, no movement
else {
//Joystick Y - Tilt movement
if (y > 60) {
y = map(y, 60, 100, 0, currentSpeed);
stepper3.setSpeed(y);
else if (y < 40) {
y = map(y, 40, 0, 0, currentSpeed);
stepper3.setSpeed(-y);
else {
BLYNK_WRITE(V17)
loopMode = param.asInt(); // assigning incoming value from pin V17 to a variable
if(loopMode==1) {
Blynk.virtualWrite(V17, HIGH);
else {
Blynk.virtualWrite(V17, LOW);
loopMode=0;
BLYNK_WRITE(V21)
stopStepper = param.asInt(); // assigning incoming value from pin V21 to a variable
if(stopStepper==1) {
Blynk.virtualWrite(V21, HIGH);
else {
Blynk.virtualWrite(V21, LOW);
stopStepper=0;
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
// Create instances for MultiStepper - Adding the 3 steppers to the StepperControl instance for multi control
StepperControl.addStepper(stepper1);
StepperControl.addStepper(stepper2);
StepperControl.addStepper(stepper3);
Blynk.virtualWrite(V4, LOW);
Blynk.virtualWrite(V9, LOW);
Blynk.virtualWrite(V12, LOW);
Blynk.virtualWrite(V1, 50);
Blynk.virtualWrite(V0, 512);
Blynk.virtualWrite(V15, 50);
Blynk.virtualWrite(V16, 50);
led.off();
led2.off();
led3.off();
led4.off();
// Execute the above commands - run the stepper motors
stepper1.runSpeed();
stepper2.runSpeed();
stepper3.runSpeed();
void GoPos01() {
led.on();
// Place the OUT position into the Array
gotoposition[0] = XPointA;
gotoposition[1] = YPointA;
gotoposition[2] = ZPointA;
stepper1.setMaxSpeed(ProgrammSpeed);
stepper2.setMaxSpeed(ProgrammSpeed);
stepper3.setMaxSpeed(ProgrammSpeed);
led.off();
void GoPos02() {
led2.on();
gotoposition[0] = XPointB;
gotoposition[1] = YPointB;
gotoposition[2] = ZPointB;
led2.off();
void GoPos03() {
led3.on();
gotoposition[0] = XPointC;
gotoposition[1] = YPointC;
gotoposition[2] = ZPointC;
led3.off();
void GoPos04() {
led4.on();
gotoposition[0] = XPointD;
gotoposition[1] = YPointD;
gotoposition[2] = ZPointD;
led4.off();
void SliderStart() {
do {
if (XPointA || YPointA || ZPointA !=0) GoPos01();
if (XPointB || YPointB || ZPointB !=0) GoPos02();
if (XPointC || YPointC || ZPointC !=0) GoPos03();
if (XPointD || YPointD || ZPointD !=0) GoPos04();
} while (loopMode==1);
