#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "M-I77X39ueL79cLf1KTow6fT8Wa81ceb"
#define BLYNK_PRINT SwSerial
float x,y,z;
#define PIN_UPTIME 10
BLYNK_READ(PIN_UPTIME)
// This command writes Arduino's uptime in seconds to Virtual Pin (5)
Blynk.virtualWrite(PIN_UPTIME, millis() / 1000);
void myTimerEvent()
x = ((analogRead(A0)*2.0)/1024.0)-1;
y = ((analogRead(A1)*2.0)/1024.0)-1;
z = ((analogRead(A2)*2.0)/1024.0)-1;
Blynk.virtualWrite (V4, x);
Blynk.virtualWrite (V5, y);
Blynk.virtualWrite (V6, z);
SwSerial.begin(115200);
Blynk.begin(Serial, auth);
I canβt seem to get it to show it in the superchart
are the values x,y,z OK if you print them to Serial?
Do you have an FTDI adapter attached to pins 10 & 11?
If so, what does your serial monitor show?
Have you edited the Blynk batch file to tell it to use the Blynk IoT server?
What do you see in the terminal window, is it showing that the device is connecting?
Is the device showing as being Online in the app and web console?
