Need help with Blynk dynamic provisioning
Dear experts,
This is my first post in Blynk community.Apologies if any thing is not properly formatted or improper.
My requirement is that nodemcu should execute the code in the absence of network connectivity also.I could find some threads in Blynk community regarding normal auth provisioning.But am working with Blynk Dynamic auth provisioning template.
I tried the below code and it works with a lot of delay in operation.Since I want to do a home automation project,normal switches should work even in the absence of Internet.With the below code,switches work with a delay of 15 to 20 seconds in the absence of network.I guess the delay is caused by the execution of
BlynkProvisioning.run(); in the loop.
#define USE_NODE_MCU_BOARD        // Comment out the boards you are not using
#define APP_DEBUG        // Comment this out to disable debug prints
#include "BlynkProvisioning.h"
  delay(500);
  BlynkProvisioning.begin();
  // This handles the network and cloud connection
if (Blynk.connected() == false) {
//HERE I WROTE CODE TO VERIFY THE PHYSICAL SWITCH CONDITION AND TRIGGER THE //OUTPUT
After going through the ConfigMode.h file in the template,I thought every time the programs waits for some time to connect to network in Loop,which might be causing the delay in executing the other part of the code.
I am pasting the ConfigMode.h file below for reference.
 * This is a DEMO. You can use it only for development and testing.
 * If you would like to add these features to your product,
 * please contact Blynk for Business:
 *                  http://www.blynk.io/
#include <ESP8266WebServer.h>
#include <ESP8266HTTPUpdateServer.h>
#include <DNSServer.h>
ESP8266WebServer server(WIFI_AP_CONFIG_PORT);
ESP8266HTTPUpdateServer httpUpdater;
DNSServer dnsServer;
const byte DNS_PORT = 53;
const char* config_form = R"html(
<!DOCTYPE HTML><html>
<form method='get' action='config'>
  <label>WiFi SSID: </label><input type="text" name="ssid" length=32 required="required"><br/>
  <label>Password:  </label><input type="text" name="pass" length=32><br/>
  <label>Auth token:</label><input type="text" name="blynk" placeholder="a0b1c2d..." pattern="[a-zA-Z0-9]{32}" maxlength="32" required="required"><br/>
  <label>Host: </label><input type="text" name="host" length=32><br/>
  <label>Port: </label><input type="number" name="port" value="8442" min="1" max="65535"><br/>
  <input type='submit' value="Apply">
</form>
</html>
)html";
void restartMCU() {
  ESP.restart();
void enterConfigMode()
  WiFi.mode(WIFI_OFF);
  delay(100);
  WiFi.mode(WIFI_AP);
  WiFi.softAPConfig(WIFI_AP_IP, WIFI_AP_IP, WIFI_AP_Subnet);
  WiFi.softAP(PRODUCT_WIFI_SSID);
  delay(500);
  IPAddress myIP = WiFi.softAPIP();
  DEBUG_PRINT(String("AP SSID: ") + PRODUCT_WIFI_SSID);
  DEBUG_PRINT(String("AP IP:   ") + myIP[0] + "." + myIP[1] + "." + myIP[2] + "." + myIP[3]);
  if (myIP == (uint32_t)0)
    BlynkState::set(MODE_ERROR);
    return;
  // Set up DNS Server
  dnsServer.setTTL(300); // Time-to-live 300s
  dnsServer.setErrorReplyCode(DNSReplyCode::ServerFailure); // Return code for non-accessible domains
#ifdef WIFI_CAPTIVE_PORTAL_ENABLE
  dnsServer.start(DNS_PORT, "*", WiFi.softAPIP()); // Point all to our IP
  server.onNotFound(handleRoot);
#else
  dnsServer.start(DNS_PORT, BOARD_CONFIG_AP_URL, WiFi.softAPIP());
  DEBUG_PRINT(String("AP URL:  ") + BOARD_CONFIG_AP_URL);
#endif
  httpUpdater.setup(&server);
  server.on("/", []() {
    server.send(200, "text/html", config_form);
  server.on("/config", []() {
    String ssid = server.arg("ssid");
    String ssidManual = server.arg("ssidManual");
    String pass = server.arg("pass");
    if (ssidManual != "") {
      ssid = ssidManual;
    String token = server.arg("blynk");
    String host  = server.arg("host");
    String port  = server.arg("port");
    String content;
    unsigned statusCode;
    DEBUG_PRINT(String("WiFi SSID: ") + ssid + " Pass: " + pass);
    DEBUG_PRINT(String("Blynk cloud: ") + token + " @ " + host + ":" + port);
    if (token.length() == 32 && ssid.length() > 0) {
      configStore.flagConfig = false;
      CopyString(ssid, configStore.wifiSSID);
      CopyString(pass, configStore.wifiPass);
      CopyString(token, configStore.cloudToken);
      if (host.length()) {
        CopyString(host,  configStore.cloudHost);
      if (port.length()) {
        configStore.cloudPort = port.toInt();
      content = R"json({"status":"ok","msg":"Configuration saved"})json";
      statusCode = 200;
      server.send(statusCode, "application/json", content);
      BlynkState::set(MODE_SWITCH_TO_STA);
      DEBUG_PRINT("Configuration invalid");
      content = R"json({"status":"error","msg":"Configuration invalid"})json";
      statusCode = 404;
  server.on("/board_info.json", []() {
    char buff[256];
    snprintf(buff, sizeof(buff),
      R"json({"board":"%s","vendor":"%s","tmpl_id":"%s","fw_ver":"%s","hw_ver":"%s"})json",
      BOARD_NAME,
      BOARD_VENDOR,
      BOARD_TEMPLATE_ID,
      BOARD_FIRMWARE_VERSION,
      BOARD_HARDWARE_VERSION
    server.send(200, "application/json", buff);
  server.on("/reset", []() {
    BlynkState::set(MODE_RESET_CONFIG);
    server.send(200, "application/json", R"json({"status":"ok","msg":"Configuration reset"})json");
  server.on("/reboot", []() {
    restartMCU();
  server.begin();
  while (BlynkState::is(MODE_WAIT_CONFIG) || BlynkState::is(MODE_CONFIGURING)) {
    dnsServer.processNextRequest();
    server.handleClient();
    if (BlynkState::is(MODE_WAIT_CONFIG) && WiFi.softAPgetStationNum() > 0) {
      BlynkState::set(MODE_CONFIGURING);
    } else if (BlynkState::is(MODE_CONFIGURING) && WiFi.softAPgetStationNum() == 0) {
      BlynkState::set(MODE_WAIT_CONFIG);
  server.stop();
void enterConnectNet() {
  BlynkState::set(MODE_CONNECTING_NET);
  DEBUG_PRINT(String("Connecting to WiFi: ") + configStore.wifiSSID);
  WiFi.mode(WIFI_STA);
  if (!WiFi.begin(configStore.wifiSSID, configStore.wifiPass))
    return;
  unsigned long timeoutMs = millis() + WIFI_NET_CONNECT_TIMEOUT;
  while ((timeoutMs > millis()) && (WiFi.status() != WL_CONNECTED))
    delay(100);
    if (!BlynkState::is(MODE_CONNECTING_NET)) {
      WiFi.disconnect();
      return;
  if (WiFi.status() == WL_CONNECTED) {
    BlynkState::set(MODE_CONNECTING_CLOUD);
void enterConnectCloud() {
  Blynk.disconnect();
  Blynk.config(configStore.cloudToken, configStore.cloudHost, configStore.cloudPort);
  Blynk.connect(0);
  unsigned long timeoutMs = millis() + WIFI_CLOUD_CONNECT_TIMEOUT;
        (Blynk.connected() == false))
    if (!BlynkState::is(MODE_CONNECTING_CLOUD)) {
      Blynk.disconnect();
      return;
  if (Blynk.connected()) {
    BlynkState::set(MODE_RUNNING);
    if (!configStore.flagConfig) {
      configStore.flagConfig = true;
      config_save();
      DEBUG_PRINT("Configuration stored to flash");
void enterSwitchToSTA() {
  DEBUG_PRINT("Switching to STA...");
void enterError() {
  unsigned long timeoutMs = millis() + 10000;
  while (timeoutMs > millis() || g_buttonPressed)
    if (!BlynkState::is(MODE_ERROR)) {
      return;
  DEBUG_PRINT("Restarting after error.");
  restartMCU();
It would be a very great help if you could help me to get out of this problem.I have tried to place interrupts for physical buttons,which is causing the board to go offline repeatedly.
Then I tried to place the “BlynkProvisioning.run();” in timer function,which was slightly better,but the delay was very inconsistent.i.e some times ,the delay is 10 seconds and some times 12 seconds.
Request your understanding if any thing sounds lame,since I am not a programmer and I learnt using Blynk with the help of online support and Blynk community.
Regards,
Mahesh.
@vshymanskyy need your eye here. Mahesh is using Blynk for Business.
@Mahesh, just to eliminate all the potential errors, could you please add full code you are using. Looks like this part can also cause delays if your code is incorrect.
@mahesh.spek
Do you need your code to be executed during Provisioning process as well? Or is it only when WiFi gets disconnected for some reason?
@Pavel @vshymanskyy I am also having the same problem in my sketch. If we do not configure the device to WIFI network then we can’t able to control the physical switch in our current implementation. Problem is BlynkProvisioning.run(); is block the entire offline sequence.
If you provide any sample sketch with BlynkProvisioning that will help us.
@maheshio you have the full sketch and you can modify it according to your needs.
Where would you put the code if you only wanted it to run when Wifi gets disconnected for some reason?
You can use BLYNK_DISCONNECTED. If you want to run it repeatedly, you could add another state (+ modify state transitions), and run your code there: https://github.com/blynkkk/blynk-library/blob/2b28da0851ffb435a8c5bb825f41dc66ee9d5f92/examples/Export_Demo/Template_ESP8266/BlynkProvisioning.h#L54
A post was split to a new topic: Re-connection issue with Blynk Edgent and NodeMCU
