Need help with 2 x DHT11
I am still new to Arduino programming with this code i am trying to get 2 DHT11 temp/humi sensor ,2 relay. when i try to add the second sensor all i get is mirror on the APP. thanks :slight_smile:
#include <Ethernet.h>
#include <dht.h>
dht DHT;
char auth[] = "***********************************"; // Write your authentication token here
WidgetLED led1(V5);
WidgetLED led2(V6);
void sendUptime()
    Blynk.virtualWrite(V4, millis() / 1000);
Blynk.begin(auth);
pinMode(8,OUTPUT);
pinMode(3,OUTPUT);
#define DHT11_PIN 7
#define DHT11_PIN 2
void blinkLedWidget()
  if (led1.getValue()) {
    led1.off();
    Serial.println("LED on V5: off");
    led1.on();
    Serial.println("LED on V5: on");
  if (led2.getValue()) {
    led2.off();
    Serial.println("LED on V6: off");
    led2.on();
    Serial.println("LED on V6: on");
int chk = DHT.read11(DHT11_PIN);
  led1.setValue(125);
  led2.setValue(125);
  Serial.print("Temperature = ");
  Serial.println(DHT.temperature,1);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity,1);
  Serial.print ("Temperature = ");
  Serial.println (DHT.temperature,2);
  Serial.print ("Humidity = ");
  Serial.println (DHT.humidity,2);
  Blynk.virtualWrite( DHT.temperature,1);
  Blynk.virtualWrite( DHT.humidity,1);
  Blynk.virtualWrite( DHT.temperature,2);
  Blynk.virtualWrite( DHT.humidity,2);
You need to name them DHT1 & DHT2
