pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(RelayPin5, OUTPUT);
pinMode(RelayPin6, OUTPUT);
pinMode(RelayPin7, OUTPUT);
pinMode(RelayPin8, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
pinMode(SwitchPin4, INPUT_PULLUP);
pinMode(SwitchPin5, INPUT_PULLUP);
pinMode(SwitchPin6, INPUT_PULLUP);
pinMode(SwitchPin7, INPUT_PULLUP);
pinMode(SwitchPin8, INPUT_PULLUP);
//During Starting all Relays should TURN OFF
digitalWrite(RelayPin1, !toggleState_1);
digitalWrite(RelayPin2, !toggleState_2);
digitalWrite(RelayPin3, !toggleState_3);
digitalWrite(RelayPin4, !toggleState_4);
digitalWrite(RelayPin5, !toggleState_5);
digitalWrite(RelayPin6, !toggleState_6);
digitalWrite(RelayPin7, !toggleState_7);
digitalWrite(RelayPin8, !toggleState_8);
digitalWrite(wifiLed, LOW);
//Blynk.begin(auth, ssid, pass);
WiFi.begin(ssid, pass);
timer.setInterval(1000L, manual_control);
timer.setInterval(2000L, checkBlynkStatus); // check if Blynk server is connected every 2 seconds
Blynk.config(auth);
if (!fetch_blynk_state){
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
Blynk.virtualWrite(VPIN_BUTTON_5, toggleState_5);
Blynk.virtualWrite(VPIN_BUTTON_6, toggleState_6);
Blynk.virtualWrite(VPIN_BUTTON_7, toggleState_7);
Blynk.virtualWrite(VPIN_BUTTON_8, toggleState_8);
thanks again
in my esp32 , when wifi is connected the blue led is glow , on my esp32 , but i want to flash ( on and off ) it when it connected automatically
Try this
void checkBlynkStatus() { // called every 2 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
wifiFlag = 1;
Serial.println("Blynk Not Connected");
if (isconnected == true) {
wifiFlag = 0;
digitalWrite(wifiLed, HIGH);
Serial.println("Blynk Connected");
timer.setTimeout(1000, []()
this error massage shows when i try to upload
Code_ESP32s_NEW_Blynk_8Relay_Switch:157:18: error: 'pumpPin' was not declared in this scope
digitalWrite(pumpPin[0], LOW);
C:\Users\kamal\Videos\1st\Code_ESP32s_NEW_Blynk_8Relay_Switch\Code_ESP32s_NEW_Blynk_8Relay_Switch.ino: In function 'void checkBlynkStatus()':
Code_ESP32s_NEW_Blynk_8Relay_Switch:159:1: error: expected ')' before '}' token
Code_ESP32s_NEW_Blynk_8Relay_Switch:161:19: error: a function-definition is not allowed here before '{' token
BLYNK_CONNECTED() {
Code_ESP32s_NEW_Blynk_8Relay_Switch:365:1: error: expected '}' at end of input
Multiple libraries were found for "WiFi.h"
Used: C:\Users\kamal\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries\WiFi
Using library WiFi at version 1.0 in folder: C:\Users\kamal\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Using library Blynk at version 1.0.1 in folder: C:\Users\kamal\Documents\Arduino\libraries\Blynk
exit status 1
You have to change pumpPin[0]
i dont understand
I’m guessing that it’s wifiLed that he wants to flash.
That’s Right.
is there any code for this
Go back to post number 24, I’ve modified it.
your massage is " You have to change pumpPin[0] " , i dont understand the meaning of pumpPin[0]
I’m using it in my sketch, it was a mistake
Post number 24 is ready, you can give it a try.
can you please edit for me, i am not understand where to past your code .
#define BLYNK_DEVICE_NAME "testing"
#define BLYNK_AUTH_TOKEN "arvMO6TX9xYpouEi8ze6T1fpc7bRRcro"
char ssid[] = "ROUTER 1";
char pass[] = "9238855k@";
bool fetch_blynk_state = true; //true or false
//#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
// define the GPIO connected with Relays and switches
#define RelayPin1 23 //D23
#define RelayPin2 22 //D22
#define RelayPin3 21 //D21
#define RelayPin4 19 //D19
#define RelayPin5 18 //D18
#define RelayPin6 5 //D5
#define RelayPin7 25 //D25
#define RelayPin8 26 //D26
#define SwitchPin1 13 //D13
#define SwitchPin2 12 //D12
#define SwitchPin3 14 //D14
#define SwitchPin4 27 //D27
#define SwitchPin5 33 //D33
#define SwitchPin6 32 //D32
#define SwitchPin7 15 //D15
#define SwitchPin8 4 //D4
#define wifiLed 2 //D2
//Change the virtual pins according the rooms
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_BUTTON_4 V4
#define VPIN_BUTTON_5 V5
#define VPIN_BUTTON_6 V6
#define VPIN_BUTTON_7 V7
#define VPIN_BUTTON_8 V8
#define VPIN_BUTTON_C V9
// Relay State
bool toggleState_1 = LOW; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = LOW; //Define integer to remember the toggle state for relay 2
bool toggleState_3 = LOW; //Define integer to remember the toggle state for relay 3
bool toggleState_4 = LOW; //Define integer to remember the toggle state for relay 4
bool toggleState_5 = LOW; //Define integer to remember the toggle state for relay 5
bool toggleState_6 = LOW; //Define integer to remember the toggle state for relay 6
bool toggleState_7 = LOW; //Define integer to remember the toggle state for relay 7
bool toggleState_8 = LOW; //Define integer to remember the toggle state for relay 8
// Switch State
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
bool SwitchState_5 = LOW;
bool SwitchState_6 = LOW;
bool SwitchState_7 = LOW;
bool SwitchState_8 = LOW;
int wifiFlag = 0;
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
toggleState_1 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_2) {
toggleState_2 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_3) {
toggleState_3 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_4) {
toggleState_4 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_5) {
toggleState_5 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_6) {
toggleState_6 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_7) {
toggleState_7 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_8) {
toggleState_8 = param.asInt();
wifiFlag = 1;
wifiFlag = 0;
BLYNK_CONNECTED() {
if (fetch_blynk_state){
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.syncVirtual(VPIN_BUTTON_3);
Blynk.syncVirtual(VPIN_BUTTON_4);
Blynk.syncVirtual(VPIN_BUTTON_5);
Blynk.syncVirtual(VPIN_BUTTON_6);
Blynk.syncVirtual(VPIN_BUTTON_7);
Blynk.syncVirtual(VPIN_BUTTON_8);
void manual_control()
if (digitalRead(SwitchPin1) == LOW && SwitchState_1 == LOW) {
digitalWrite(RelayPin1, LOW);
toggleState_1 = 1;
SwitchState_1 = HIGH;
Serial.println("Switch-1 on");
if (digitalRead(SwitchPin1) == HIGH && SwitchState_1 == HIGH) {
digitalWrite(RelayPin1, HIGH);
toggleState_1 = 0;
Serial.println("Switch-1 off");
if (digitalRead(SwitchPin2) == LOW && SwitchState_2 == LOW) {
digitalWrite(RelayPin2, LOW);
toggleState_2 = 1;
SwitchState_2 = HIGH;
Serial.println("Switch-2 on");
if (digitalRead(SwitchPin2) == HIGH && SwitchState_2 == HIGH) {
digitalWrite(RelayPin2, HIGH);
toggleState_2 = 0;
Serial.println("Switch-2 off");
if (digitalRead(SwitchPin3) == LOW && SwitchState_3 == LOW) {
digitalWrite(RelayPin3, LOW);
toggleState_3 = 1;
SwitchState_3 = HIGH;
Serial.println("Switch-3 on");
if (digitalRead(SwitchPin3) == HIGH && SwitchState_3 == HIGH) {
digitalWrite(RelayPin3, HIGH);
toggleState_3 = 0;
Serial.println("Switch-3 off");
if (digitalRead(SwitchPin4) == LOW && SwitchState_4 == LOW) {
digitalWrite(RelayPin4, LOW);
toggleState_4 = 1;
SwitchState_4 = HIGH;
Serial.println("Switch-4 on");
if (digitalRead(SwitchPin4) == HIGH && SwitchState_4 == HIGH) {
digitalWrite(RelayPin4, HIGH);
toggleState_4 = 0;
Serial.println("Switch-4 off");
if (digitalRead(SwitchPin5) == LOW && SwitchState_5 == LOW) {
digitalWrite(RelayPin5, LOW);
toggleState_5 = 1;
SwitchState_5 = HIGH;
Serial.println("Switch-5 on");
if (digitalRead(SwitchPin5) == HIGH && SwitchState_5 == HIGH) {
digitalWrite(RelayPin5, HIGH);
toggleState_5 = 0;
Serial.println("Switch-5 off");
if (digitalRead(SwitchPin6) == LOW && SwitchState_6 == LOW) {
digitalWrite(RelayPin6, LOW);
toggleState_6 = 1;
SwitchState_6 = HIGH;
Serial.println("Switch-6 on");
if (digitalRead(SwitchPin6) == HIGH && SwitchState_6 == HIGH) {
digitalWrite(RelayPin6, HIGH);
toggleState_6 = 0;
Serial.println("Switch-6 off");
if (digitalRead(SwitchPin7) == LOW && SwitchState_7 == LOW) {
digitalWrite(RelayPin7, LOW);
toggleState_7 = 1;
SwitchState_7 = HIGH;
Serial.println("Switch-7 on");
if (digitalRead(SwitchPin7) == HIGH && SwitchState_7 == HIGH) {
digitalWrite(RelayPin7, HIGH);
toggleState_7 = 0;
Serial.println("Switch-7 off");
if (digitalRead(SwitchPin8) == LOW && SwitchState_8 == LOW) {
digitalWrite(RelayPin8, LOW);
toggleState_8 = 1;
SwitchState_8 = HIGH;
Serial.println("Switch-8 on");
if (digitalRead(SwitchPin8) == HIGH && SwitchState_8 == HIGH) {
digitalWrite(RelayPin8, HIGH);
toggleState_8 = 0;
Serial.println("Switch-8 off");
BLYNK_WRITE(VPIN_BUTTON_C) {
all_SwitchOff();
void all_SwitchOff(){
toggleState_1 = 0; digitalWrite(RelayPin1, HIGH); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
toggleState_2 = 0; digitalWrite(RelayPin2, HIGH); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
toggleState_3 = 0; digitalWrite(RelayPin3, HIGH); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
toggleState_5 = 0; digitalWrite(RelayPin5, HIGH); Blynk.virtualWrite(VPIN_BUTTON_5, toggleState_5); delay(100);
toggleState_6 = 0; digitalWrite(RelayPin6, HIGH); Blynk.virtualWrite(VPIN_BUTTON_6, toggleState_6); delay(100);
toggleState_7 = 0; digitalWrite(RelayPin7, HIGH); Blynk.virtualWrite(VPIN_BUTTON_7, toggleState_7); delay(100);
toggleState_8 = 0; digitalWrite(RelayPin8, HIGH); Blynk.virtualWrite(VPIN_BUTTON_8, toggleState_8); delay(100);
Blynk.config(auth);
#include <WiFi.h>
// Relay State
// Switch State
int wifiFlag = 0;
wifiFlag = 1;
wifiFlag = 0;
BLYNK_CONNECTED() {
toggleState_1 = 1;
toggleState_1 = 0;
toggleState_2 = 1;
toggleState_2 = 0;
toggleState_3 = 1;
toggleState_3 = 0;
toggleState_4 = 1;
toggleState_4 = 0;
toggleState_5 = 1;
toggleState_5 = 0;
toggleState_6 = 1;
toggleState_6 = 0;
toggleState_7 = 1;
toggleState_7 = 0;
toggleState_8 = 1;
toggleState_8 = 0;
all_SwitchOff();
Blynk.config(auth);
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "DOIT ESP32 DEVKIT V1, 80MHz, 921600, None"
C:\Users\kamal\Pictures\1st\Code_ESP32s_NEW_Blynk_8Relay_Switch\Code_ESP32s_NEW_Blynk_8Relay_Switch.ino: In function 'void checkBlynkStatus()':
BLYNK_CONNECTED() {
exit status 1
fixed, try again.
use latest but same problem i think happen
Code_ESP32s_NEW_Blynk_8Relay_Switch:159:3: error: expected ')' before '}' token
Using library Blynk at version 1.1.0 in folder: C:\Users\kamal\Documents\Arduino\libraries\Blynk
exit status 1
I’m not home at the moment, I’m using my phone.
I will check it when I get back to home.
