SIm 900 is being used over software serial on arduino board . Can someone please explain how to use sim900 module’st GPRS service so I can use the blynk cloud to operate. As if for now I can connect my module to GPRS service using the codes.
Sim900 is not supported yet. You can try integrating it yourself, abd we can provide some technical support.
SIM900 has complete TCP/IP stack built in should be fairly easy to integrate Blynk if I’m correct?
