Hello, Everyone, i am controlling fan speed using relay module with the help of blynk app, but the problem is my slider keep moving can some one help me,
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define DEBUG_SW 1
// Pins of Fan Regulator Knob
#define s1 27
#define s2 14
#define s3 12
#define s4 13
// Pins of Switches
#define S5 32
#define S6 35
#define S7 34
#define S8 39
// Pins of Relay (Appliances Control)
#define R5 15
#define R6 2
#define R7 4
#define R8 22
// Pins of Relay (Fan Speed Control)
#define Speed1 21
#define Speed2 19
#define Speed4 18
// By default the mode is with_internet
int MODE = 0;
char auth[] = ",,,,,,,,,,,,,,,,,,,,,,,,,,";
char ssid[] = "Yogendra";
char pass[] = "Jamsariya";
bool speed1_flag = 1;
bool speed2_flag = 1;
bool speed3_flag = 1;
bool speed4_flag = 1;
bool speed0_flag = 1;
int switch_ON_Flag1_previous_I = 0;
int switch_ON_Flag2_previous_I = 0;
int switch_ON_Flag3_previous_I = 0;
int switch_ON_Flag4_previous_I = 0;
BLYNK_WRITE(V0)
int fan_speed = param.asInt(); // assigning incoming value from pin V1 to a variable
if (fan_speed == 0)
speed0();
if (fan_speed == 1)
speed1();
if (fan_speed == 2)
speed2();
if (fan_speed == 3)
speed3();
if (fan_speed == 4)
speed4();
BLYNK_WRITE(V1)
digitalWrite(R5, pinValue);
// process received value
BLYNK_WRITE(V2)
int pinValue = param.asInt(); // assigning incoming value from pin V2 to a variable
digitalWrite(R6, pinValue);
BLYNK_WRITE(V3)
int pinValue = param.asInt(); // assigning incoming value from pin V3 to a variable
digitalWrite(R7, pinValue);
BLYNK_WRITE(V4)
int pinValue = param.asInt(); // assigning incoming value from pin V4 to a variable
digitalWrite(R8, pinValue);
pinMode(s1, INPUT);
pinMode(s2, INPUT);
pinMode(s3, INPUT_PULLUP);
pinMode(s4, INPUT);
pinMode(S5, INPUT);
pinMode(S6, INPUT);
pinMode(S7, INPUT);
pinMode(S8, INPUT);
pinMode(R5, OUTPUT);
pinMode(R6, OUTPUT);
pinMode(R7, OUTPUT);
pinMode(R8, OUTPUT);
pinMode(Speed1, OUTPUT);
pinMode(Speed2, OUTPUT);
pinMode(Speed4, OUTPUT);
WiFi.begin(ssid, pass);
timer.setInterval(3000L, checkBlynk); // check if connected to Blynk server every 3 seconds
Blynk.config(auth);//, ssid, pass);
if (WiFi.status() != WL_CONNECTED)
if (DEBUG_SW) Serial.println("Not Connected");
if (DEBUG_SW) Serial.println(" Connected");
if (MODE == 0)
with_internet();
without_internet();
void with_internet()
// FOR FAN
if (digitalRead(s1) == LOW && speed1_flag == 1)
speed1();
Blynk.virtualWrite(V0, 1);
speed1_flag = 0;
speed2_flag = 1;
speed3_flag = 1;
speed4_flag = 1;
speed0_flag = 1;
if (digitalRead(s2) == LOW && digitalRead(s3) == HIGH && speed2_flag == 1)
speed2();
Blynk.virtualWrite(V0, 2);
speed1_flag = 1;
speed2_flag = 0;
speed3_flag = 1;
speed4_flag = 1;
speed0_flag = 1;
if (digitalRead(s2) == LOW && digitalRead(s3) == LOW && speed3_flag == 1)
speed3();
Blynk.virtualWrite(V0, 3);
speed1_flag = 1;
speed2_flag = 1;
speed3_flag = 0;
speed4_flag = 1;
speed0_flag = 1;
if (digitalRead(s4) == LOW && speed4_flag == 1)
speed4();
Blynk.virtualWrite(V0, 4);
speed1_flag = 1;
speed2_flag = 1;
speed3_flag = 1;
speed4_flag = 0;
speed0_flag = 1;
if (digitalRead(s1) == HIGH && digitalRead(s2) == HIGH && digitalRead(s3) == HIGH && digitalRead(s4) == HIGH && speed0_flag == 1)
speed0();
Blynk.virtualWrite(V0, 0);
speed1_flag = 1;
speed2_flag = 1;
speed3_flag = 1;
speed4_flag = 1;
speed0_flag = 0;
// FOR SWITCH
if (digitalRead(S5) == LOW)
if (switch_ON_Flag1_previous_I == 0 )
digitalWrite(R5, HIGH);
if (DEBUG_SW) Serial.println("Relay1- ON");
Blynk.virtualWrite(V1, 1);
switch_ON_Flag1_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch1 -ON");
if (digitalRead(S5) == HIGH )
if (switch_ON_Flag1_previous_I == 1)
digitalWrite(R5, LOW);
if (DEBUG_SW) Serial.println("Relay1 OFF");
Blynk.virtualWrite(V1, 0);
if (DEBUG_SW)Serial.println("Switch1 OFF");
if (digitalRead(S6) == LOW)
if (switch_ON_Flag2_previous_I == 0 )
digitalWrite(R6, HIGH);
if (DEBUG_SW) Serial.println("Relay2- ON");
Blynk.virtualWrite(V2, 1);
switch_ON_Flag2_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch2 -ON");
if (digitalRead(S6) == HIGH )
if (switch_ON_Flag2_previous_I == 1)
digitalWrite(R6, LOW);
if (DEBUG_SW) Serial.println("Relay2 OFF");
Blynk.virtualWrite(V2, 0);
if (DEBUG_SW)Serial.println("Switch2 OFF");
//delay(200);
if (digitalRead(S7) == LOW)
if (switch_ON_Flag3_previous_I == 0 )
digitalWrite(R7, HIGH);
if (DEBUG_SW) Serial.println("Relay3- ON");
Blynk.virtualWrite(V3, 1);
switch_ON_Flag3_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch3 -ON");
if (digitalRead(S7) == HIGH )
if (switch_ON_Flag3_previous_I == 1)
digitalWrite(R7, LOW);
if (DEBUG_SW) Serial.println("Relay3 OFF");
Blynk.virtualWrite(V3, 0);
if (DEBUG_SW)Serial.println("Switch3 OFF");
//delay(200);
if (digitalRead(S8) == LOW)
if (switch_ON_Flag4_previous_I == 0 )
digitalWrite(R8, HIGH);
if (DEBUG_SW) Serial.println("Relay4- ON");
Blynk.virtualWrite(V4, 1);
switch_ON_Flag4_previous_I = 1;
if (DEBUG_SW) Serial.println("Switch4 -ON");
if (digitalRead(S8) == HIGH )
if (switch_ON_Flag4_previous_I == 1)
digitalWrite(R8, LOW);
if (DEBUG_SW) Serial.println("Relay4 OFF");
Blynk.virtualWrite(V4, 0);
if (DEBUG_SW) Serial.println("Switch4 OFF");
//delay(200);
void without_internet()
// FOR FAN
speed1();
speed1_flag = 0;
speed2_flag = 1;
speed3_flag = 1;
speed4_flag = 1;
speed0_flag = 1;
speed2();
speed1_flag = 1;
speed2_flag = 0;
speed3_flag = 1;
speed4_flag = 1;
speed0_flag = 1;
speed3();
speed1_flag = 1;
speed2_flag = 1;
speed3_flag = 0;
speed4_flag = 1;
speed0_flag = 1;
speed4();
speed1_flag = 1;
speed2_flag = 1;
speed3_flag = 1;
speed4_flag = 0;
speed0_flag = 1;
speed0();
speed1_flag = 1;
speed2_flag = 1;
speed3_flag = 1;
speed4_flag = 1;
speed0_flag = 0;
// FOR SWITCH
digitalWrite(R5, !digitalRead(S5));
digitalWrite(R6, !digitalRead(S6));
digitalWrite(R7, !digitalRead(S7));
digitalWrite(R8, !digitalRead(S8));
// Fan Speed Control
void speed0()
//All Relays Off - Fan at speed 0
if (DEBUG_SW)Serial.println("SPEED 0");
digitalWrite(Speed1, LOW);
digitalWrite(Speed2, LOW);
digitalWrite(Speed4, LOW);
void speed1()
//Speed1 Relay On - Fan at speed 1
if (DEBUG_SW)Serial.println("SPEED 1");
digitalWrite(Speed1, HIGH);
void speed2()
//Speed2 Relay On - Fan at speed 2
if (DEBUG_SW)Serial.println("SPEED 2");
digitalWrite(Speed2, HIGH);
void speed3()
//Speed1 & Speed2 Relays On - Fan at speed 3
if (DEBUG_SW)Serial.println("SPEED 3");
void speed4()
//Speed4 Relay On - Fan at speed 4
if (DEBUG_SW)Serial.println("SPEED 4");
digitalWrite(Speed4, HIGH);
//Check Blynk Connectivity every 3 seconds
void checkBlynk()
bool isconnected = Blynk.connected();
if (isconnected == false)
MODE = 1;
if (isconnected == true)
MODE = 0;
**This Code is written By Sachin Soni, all Creadit goes to him please Watch and susbcrible his youtube channel
this is the link of about this project- https://youtu.be/hKyoRHOGwy4 **
