Hey, Iβm trying to make a watering system using the code from Emilostuff β Emil Skydsgaard, 2020, who wrote it originally for an esp8266. After changing the code I now tried to compile it, but unfortunately, I always get an error message. Would be great if someone could help me
(GitHub - Emilostuff/PlantKeeper: Automated Plant Watering System)
β’ Hardware model + communication type: Esp32 with WiFi
β’ Smartphone OS (iOS)
β’ Blynk server
// Libraries
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include<Wire.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
// Networking
char auth[] = "Blynk token";
char ssid[] = "Network name";
char pass[] = "Password";
// Blynk
BlynkTimer timer1;
WidgetRTC rtc;
// System state
int plantSelect = 0; // plant 1 selected on default (index 0)
bool systemOn = 0;
bool systFlag = false;
long ontime;
long lastWater[4] = {0, 0, 0, 0}; // 0 means not set
bool pumpOn[4] = {false, false, false, false};
// Settings (can be adjusted from app)
int modes[4] = {0, 0, 0, 0};
int amount[4] = {0, 0, 0, 0};
int interval[4] = {0, 0, 0, 0};
int thresh[4] = {0, 0, 0, 0};
int minInterval[4] = {0, 0, 0, 0};
// sensor/ADC
ADS1115_WE adc(0x48);
float tf = 0.1; // trust factor for smoothing filter
float sensor[4] = {100, 100, 100, 100}; // Set highest start value to avoid unwanted triggers
float sensorDry[4] = {2760, 2680, 2780, 2760}; // Reading from when fully emerged in water
float sensorWet[4] = {1460, 1210, 1510, 1500}; // Reading from when in 'dry' air
// BLYNK ///////////////////////////////////////
BLYNK_CONNECTED()
// Synchronize unix-time on connection
rtc.begin();
// IN-APP EVENT CALLS ///////////////////////
// for when the user presses any button in the app
// System on-off button event
BLYNK_WRITE(V7)
// change system state
systemOn = param.asInt();
if (systemOn) {
if (systFlag) {
// system has just been turned on!
systFlag = false;
// set lastWater to now:
ontime = now();
Blynk.virtualWrite(V34, ontime, ontime, ontime, ontime);
Blynk.syncVirtual(V34);
// system was turned on when connected -> do nothing
// system is off
systFlag = true;
Unfortunately I get this error
PlantKeeper_public:75:59: error: variable or field 'BlynkWidgetWrite7' declared void
PlantKeeper_public:75:24: error: 'BlynkReq' was not declared in this scope
