Need help for my project speed cotrol of dc motor?
hi frnds…i have arduino uno and w5100 ethernet shield…i need help for my project…
Can you make it work without Blynk?
Just control DC motors with Arduino UNO? without Ethernet shield?
sir,
i have done the speed control of dc motor using arduino uno bt my final year project is web based control of dc motor…i am not well in programming…so i need your help.i hopefully expect an reply…
Thank you sir
Could you post your code?
It seems that all you need is just to get data from the Blynk app using Virtual Pins and write the values to the motors…
you can read about Virtual Pins here:
http://docs.blynk.cc/#blynk-main-operations-virtual-pins
thank you for u r valuable information…if i have any queries…i will be back…
thanks sir
