Disregard my guess at using Ethernet.begin() and try again as you had it, but with proper port 8442 this time…
Blynk.begin(auth, server_ip, 8442, arduino_ip, dns_ip, gateway_ip, subnet_mask, arduino_mac);
#include <Ethernet.h>
char auth[] = "42f90c53c83c4816b1483b8c18ef8c97";
IPAddress server_ip (192, 168, 1, 46);
// Mac address should be different for each device in your LAN
byte arduino_mac[] = { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
IPAddress arduino_ip ( 192, 168, 1, 47);
IPAddress dns_ip (192, 168, 1, 1);
IPAddress gateway_ip (192, 168, 1, 1);
IPAddress subnet_mask(255, 255, 255, 0);
#define W5100_CS 10
#define SDCARD_CS 4
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
//Ethernet.begin( server_ip, 8442,arduino_mac, arduino_ip, gateway_ip, subnet_mask);
//Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 8442);
//Blynk.begin(auth, IPAddress(192,168,1,46), 8443);
// to avoid delay() function!
still didnt work @Gunner
[0] Using static IP
[1300] IP:192.168.1.47
[1300]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.8 on Arduino Uno
[5001] Connecting to 192.168.1.46
[10002] Connecting to 192.168.1.46
So it looks like you are using a Local Server… is that the correct address for sure? Have you ever connected to it with this or any other device?
Try a similar sketch, but using a Blynk cloud account and server.
yeah im using local server. i can ping all the devices my server, arduino and ip of my phone. i already tried the blynk server but still getting worst serial monitor says ip dhcp error. thanks for answering my questions @Gunner
Hi @distans, More on this issue in this thread:
It’s along time since I used the w5100 shield, but my issue wasn’t caused by duplicate MAC addresses. The shield would work when plugged directly into the router, but not when plugged into a L2 switch that was then connected to the router.
It doesn’t seem that this is the issue in this case, but worth bearing in mind for the future is you’re using these Ethernet shields.
How did you solve it? Could be a good reference for others
Should I post my comment in the “W5100” thread you linked to? @Gunner isn’t always happy when old threads get bumped, but it would be more related there
Or do nothing since it’s almost an obsolete hardware ![]()
I think posting in old threads makes sense if it’s relevant to the topic and not superseded by changes to Blynk or the libraries. That way, when (okay, IF) someone searches for that issue then have all the info in one place.
You could always start with "I know this is an old thread, but…), that way you’re less likely to incur the wrath of the mighty and worshipful @Gunner
As you say, it’s not exactly cutting edge hardware anymore, and most people that used Ethernet shields seem to have made the dubious transition to connecting an ESP to an Arduino instead, but it takes all sorts to make the world go Blink.
And therein lies the problem… it is rarely relevant and more often just an unrelated “Me Toos” leading to a very long and twisting topic full of contradictions and confusion. ![]()
One day I am going to retire from this high paying, low effort ‘job’, then you will all be free ![]()
I originally started off with USB, then transitioned to Ethernet, then back to USB (which I still use for some devices as it seems rock solid now) and on to a mixture of ESP shields and standalones. But I do not miss the hassle of that flaky Ethernet shield ![]()
i only change the port to 8442 and suddenly it work
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Uno board
example.
IPAddress server_ip (192, 168, 1, 47);
IPAddress arduino_ip ( 192, 168, 1, 55);
#define W5100_CS 10
#define SDCARD_CS 4
BLYNK_WRITE(V16) // V5 is the number of Virtual Pin
int pinValue = param.asInt();
Wasn’t that like the first thing I told you to correct in your settings? ![]()
