I need help with creating a project that uses the blynk app to connect to the raspberry pi 3 in order to turn a servo motor from 90 degrees to 0. I don’t know how or where to start and have been looking for any form of tutorial or guidance to help.
Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.Code should be formatted as example below.
