Need help converting Blynk WiFiManager code from ESP8266 to ESP32
hello
I have code for esp8266 need change to esp32 please help me need help
I have seen it changetirib error coming out
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
//#define BLYNK_DEBUG
//define your default values here, if there are different values in config.json, they are overwritten.
char mqtt_server[40]= "";
char mqtt_port[6] = "";
char blynk_token[34] = "";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
  Serial.println();
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(blynk_token, json["blynk_token"]);
          Serial.println("failed to load json config");
    Serial.println("failed to mount FS");
  //end read
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  //wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  //add all your parameters here
  wifiManager.addParameter(&custom_mqtt_server);
  wifiManager.addParameter(&custom_mqtt_port);
  wifiManager.addParameter(&custom_blynk_token);
  //reset settings - for testing
  //wifiManager.resetSettings();
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  //wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("Wifi_Manager", "")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  Serial.println("connected...yeey :)");
  //read updated parameters
  strcpy(mqtt_server, custom_mqtt_server.getValue());
 strcpy(mqtt_port, custom_mqtt_port.getValue());
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["mqtt_server"] = mqtt_server;
    json["mqtt_port"] = mqtt_port;
    json["blynk_token"] = blynk_token;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
  //Serial.println("local ip");
  //Serial.println(WiFi.localIP());
  Blynk.config(blynk_token, mqtt_server, 8080);
  bool result = Blynk.connect();
if (result != true)
  Serial.println("BLYNK Connection Fail");
  Serial.println(blynk_token);
  ESP.reset();
  delay (5000);
  Serial.println("BLYNK Connected");
it has been modified
#include "SPIFFS.h"
#include <WiFi.h>          //https://github.com/esp8266/Arduino
#include <BlynkSimpleEsp32.h>
char mqtt_server[40]= "blynk.jpnet.co.th";
char mqtt_port[6] = "8080";
char blynk_token[34] = "iixJ13mUOKZ3ziNSBcgRYT9K-FS9bonL";
  Serial.println();
  //SPIFFS.format();
      if (configFile) {
  //end read
  //WiFiManager
  //set static ip
  //defaults to 8%
  //in seconds
    delay(3000);
    ESP.restart();
    delay(5000);
    if (!configFile) {
    configFile.close();
    //end save
  Blynk.config(blynk_token);
if (result != true)
  ESP.restart();
  delay (5000);
so making a mistake
C:\Users\n1\Documents\Arduino\libraries\WiFiManager-master\WiFiManager.cpp: In member function ‘void WiFiManager::handleRequest()’:
C:\Users\n1\Documents\Arduino\libraries\WiFiManager-master\WiFiManager.cpp:1200:35: error: ‘HTTP Auth Method’ has not been declared
server->request Authentication(HTTP Auth Method::BASIC_AUTH); // DIGEST_AUTH
Several libraries found for “BlynkSimpleEsp32.h”
are used: C:\Users\n1\Documents\Arduino\libraries\Blynk
Not used: C:\Program Files\arduino\libraries\link-library-master
Hi Blynkers,
  Serial.println();
  //SPIFFS.format();
      if (configFile) {
  //end read
  //WiFiManager
  //set static ip
  //defaults to 8%
  //in seconds
    delay(3000);
    ESP.reset();
    delay(5000);
    if (!configFile) {
    configFile.close();
    //end save
if (result != true)
  ESP.reset();
  delay (5000);
#include "SPIFFS.h"
  Serial.println();
  //SPIFFS.format();
      if (configFile) {
  //end read
  //WiFiManager
  //set static ip
  //defaults to 8%
  //in seconds
    delay(3000);
    ESP.restart();
    delay(5000);
    if (!configFile) {
    configFile.close();
    //end save
if (result != true)
  ESP.restart();
  delay (5000);
so making a mistake
I’ve moved your posts into a single new topic.
You may wish to take the opportunity to delete any duplications, to make it easier for forum members to follow, and provide the following information (which you are asked for when you create a new topic)…
  1. Add details :
    • Smartphone OS (iOS or Android) + Blynk App version
    • Blynk Library version
