Need Help Combining two sketches into one
HI here, i have an RFID Door Access Sketch i’m running on my Arduino Mega and would like to run Blynk as well on the same arduino. I’ve tried taking blynk code apart but blynk isn’t running. Here is a copy of my RFID sketch, can anyone please insert the code for me and repost it.
#include <EEPROM.h>     // We are going to read and write PICC's UIDs from/to EEPROM
#include <SPI.h>        // RC522 Module uses SPI protocol
#include <MFRC522.h>	// Library for Mifare RC522 Devices
	Instead of a Relay maybe you want to use a servo
	Servos can lock and unlock door locks too
	There are examples out there.
// #include <Servo.h>
	For visualizing whats going on hardware
	we need some leds and
	to control door lock a relay and a wipe button
	(or some other hardware)
	Used common anode led,digitalWriting HIGH turns OFF led
	Mind that if you are going to use common cathode led or
	just seperate leds, simply comment out #define COMMON_ANODE,
#ifdef COMMON_ANODE
#define LED_ON LOW
#define LED_OFF HIGH
#else
#define LED_ON HIGH
#define LED_OFF LOW
#endif
#define redLed 7		// Set Led Pins
#define greenLed 6
#define blueLed 5
#define relay 4			// Set Relay Pin
#define wipeB 3			// Button pin for WipeMode
boolean match = false;          // initialize card match to false
boolean programMode = false;	// initialize programming mode to false
boolean replaceMaster = false;
int successRead;		// Variable integer to keep if we have Successful Read from Reader
byte storedCard[4];		// Stores an ID read from EEPROM
byte readCard[4];		// Stores scanned ID read from RFID Module
byte masterCard[4];		// Stores master card's ID read from EEPROM
	We need to define MFRC522's pins and create instance
	Pin layout should be as follows (on Arduino Uno):
	MOSI: Pin 11 / ICSP-4
	MISO: Pin 12 / ICSP-1
	SCK : Pin 13 / ICSP-3
	SS : Pin 10 (Configurable)
	RST : Pin 9 (Configurable)
	look MFRC522 Library for
	other Arduinos' pin configuration
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance.
///////////////////////////////////////// Setup ///////////////////////////////////
  //Arduino Pin Configuration
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(blueLed, OUTPUT);
  pinMode(wipeB, INPUT_PULLUP);		// Enable pin's pull up resistor
  pinMode(relay, OUTPUT);
  //Be careful how relay circuit behave on while resetting or power-cycling your Arduino
  digitalWrite(relay, HIGH);		// Make sure door is locked
  digitalWrite(redLed, LED_OFF);	// Make sure led is off
  digitalWrite(greenLed, LED_OFF);	// Make sure led is off
  digitalWrite(blueLed, LED_OFF);	// Make sure led is off
  //Protocol Configuration
  Serial.begin(9600);	 // Initialize serial communications with PC
  SPI.begin();           // MFRC522 Hardware uses SPI protocol
  mfrc522.PCD_Init();    // Initialize MFRC522 Hardware
  //If you set Antenna Gain to Max it will increase reading distance
  //mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max);
  Serial.println(F("Access Control v3.4"));   // For debugging purposes
  ShowReaderDetails();	// Show details of PCD - MFRC522 Card Reader details
  //Wipe Code if Button Pressed while setup run (powered on) it wipes EEPROM
  if (digitalRead(wipeB) == LOW) {	// when button pressed pin should get low, button connected to ground
    digitalWrite(redLed, LED_ON);	// Red Led stays on to inform user we are going to wipe
    Serial.println(F("Wipe Button Pressed"));
    Serial.println(F("You have 15 seconds to Cancel"));
    Serial.println(F("This will be remove all records and cannot be undone"));
    delay(15000);                        // Give user enough time to cancel operation
    if (digitalRead(wipeB) == LOW) {    // If button still be pressed, wipe EEPROM
      Serial.println(F("Starting Wiping EEPROM"));
      for (int x = 0; x < EEPROM.length(); x = x + 1) {    //Loop end of EEPROM address
        if (EEPROM.read(x) == 0) {              //If EEPROM address 0
          // do nothing, already clear, go to the next address in order to save time and reduce writes to EEPROM
        else {
          EEPROM.write(x, 0); 			// if not write 0 to clear, it takes 3.3mS
      Serial.println(F("EEPROM Successfully Wiped"));
      digitalWrite(redLed, LED_OFF); 	// visualize successful wipe
      delay(200);
      delay(200);
      delay(200);
      delay(200);
    else {
      Serial.println(F("Wiping Cancelled"));
  // Check if master card defined, if not let user choose a master card
  // This also useful to just redefine Master Card
  // You can keep other EEPROM records just write other than 143 to EEPROM address 1
  // EEPROM address 1 should hold magical number which is '143'
  if (EEPROM.read(1) != 143) {
    Serial.println(F("No Master Card Defined"));
    Serial.println(F("Scan A PICC to Define as Master Card"));
    do {
      successRead = getID();            // sets successRead to 1 when we get read from reader otherwise 0
      digitalWrite(blueLed, LED_ON);    // Visualize Master Card need to be defined
      delay(200);
      delay(200);
    while (!successRead);                  // Program will not go further while you not get a successful read
    for ( int j = 0; j < 4; j++ ) {        // Loop 4 times
      EEPROM.write( 2 + j, readCard[j] );  // Write scanned PICC's UID to EEPROM, start from address 3
    EEPROM.write(1, 143);                  // Write to EEPROM we defined Master Card.
    Serial.println(F("Master Card Defined"));
  Serial.println(F("-------------------"));
  Serial.println(F("Master Card's UID"));
  for ( int i = 0; i < 4; i++ ) {          // Read Master Card's UID from EEPROM
    masterCard[i] = EEPROM.read(2 + i);    // Write it to masterCard
    Serial.print(masterCard[i], HEX);
  Serial.println("");
  Serial.println(F("Everything Ready"));
  Serial.println(F("Waiting PICCs to be scanned"));
  cycleLeds();    // Everything ready lets give user some feedback by cycling leds
///////////////////////////////////////// Main Loop ///////////////////////////////////
void loop () {
  do {
      digitalWrite(redLed, LED_ON);  // Make sure led is off
      Serial.println(F("Master Card will be Erased! in 10 seconds"));
      delay(10000);
        EEPROM.write(1, 0);                  // Reset Magic Number.
        Serial.println(F("Restart device to re-program Master Card"));
        while (1);
    if (programMode) {
      cycleLeds();              // Program Mode cycles through RGB waiting to read a new card
    else {
      normalModeOn(); 		// Normal mode, blue Power LED is on, all others are off
  while (!successRead); 	//the program will not go further while you not get a successful read
  if (programMode) {
    if ( isMaster(readCard) ) { //If master card scanned again exit program mode
      Serial.println(F("Master Card Scanned"));
      Serial.println(F("Exiting Program Mode"));
      Serial.println(F("-----------------------------"));
      return;
    else {
      if ( findID(readCard) ) { // If scanned card is known delete it
        Serial.println(F("I know this PICC, removing..."));
        deleteID(readCard);
        Serial.println("-----------------------------");
        Serial.println(F("Scan a PICC to ADD or REMOVE to EEPROM"));
      else {                    // If scanned card is not known add it
        Serial.println(F("I do not know this PICC, adding..."));
        writeID(readCard);
  else {
    if ( isMaster(readCard)) {  	// If scanned card's ID matches Master Card's ID enter program mode
      programMode = true;
      Serial.println(F("Hello Master - Entered Program Mode"));
      int count = EEPROM.read(0); 	// Read the first Byte of EEPROM that
      Serial.print(F("I have "));    	// stores the number of ID's in EEPROM
      Serial.print(count);
      Serial.print(F(" record(s) on EEPROM"));
      Serial.println("");
      Serial.println(F("Scan Master Card again to Exit Program Mode"));
    else {
      if ( findID(readCard) ) {	// If not, see if the card is in the EEPROM
        Serial.println(F("Welcome, You shall pass"));
        granted(300);        	// Open the door lock for 300 ms
      else {			// If not, show that the ID was not valid
        Serial.println(F("You shall not pass"));
        denied();
/////////////////////////////////////////  Access Granted    ///////////////////////////////////
void granted (int setDelay) {
  digitalWrite(blueLed, LED_OFF); 	// Turn off blue LED
  digitalWrite(redLed, LED_OFF); 	// Turn off red LED
  digitalWrite(greenLed, LED_ON); 	// Turn on green LED
  digitalWrite(relay, LOW); 		// Unlock door!
  delay(setDelay); 					// Hold door lock open for given seconds
  digitalWrite(relay, HIGH); 		// Relock door
  delay(1000); 						// Hold green LED on for a second
///////////////////////////////////////// Access Denied  ///////////////////////////////////
void denied() {
  digitalWrite(greenLed, LED_OFF); 	// Make sure green LED is off
  digitalWrite(blueLed, LED_OFF); 	// Make sure blue LED is off
  digitalWrite(redLed, LED_ON); 	// Turn on red LED
///////////////////////////////////////// Get PICC's UID ///////////////////////////////////
int getID() {
  // Getting ready for Reading PICCs
  if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
    return 0;
  if ( ! mfrc522.PICC_ReadCardSerial()) {   //Since a PICC placed get Serial and continue
    return 0;
  // There are Mifare PICCs which have 4 byte or 7 byte UID care if you use 7 byte PICC
  // I think we should assume every PICC as they have 4 byte UID
  // Until we support 7 byte PICCs
  Serial.println(F("Scanned PICC's UID:"));
  for (int i = 0; i < 4; i++) {  //
    readCard[i] = mfrc522.uid.uidByte[i];
    Serial.print(readCard[i], HEX);
  Serial.println("");
  mfrc522.PICC_HaltA(); // Stop reading
  return 1;
void ShowReaderDetails() {
  // Get the MFRC522 software version
  byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
  Serial.print(F("MFRC522 Software Version: 0x"));
  Serial.print(v, HEX);
  if (v == 0x91)
    Serial.print(F(" = v1.0"));
  else if (v == 0x92)
    Serial.print(F(" = v2.0"));
    Serial.print(F(" (unknown),probably a chinese clone?"));
  Serial.println("");
  // When 0x00 or 0xFF is returned, communication probably failed
  if ((v == 0x00) || (v == 0xFF)) {
    Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
    Serial.println(F("SYSTEM HALTED: Check connections."));
    while (true); // do not go further
///////////////////////////////////////// Cycle Leds (Program Mode) ///////////////////////////////////
void cycleLeds() {
  digitalWrite(redLed, LED_OFF); 	// Make sure red LED is off
  digitalWrite(greenLed, LED_ON); 	// Make sure green LED is on
  delay(200);
  digitalWrite(blueLed, LED_ON); 	// Make sure blue LED is on
  delay(200);
  digitalWrite(redLed, LED_ON); 	// Make sure red LED is on
  delay(200);
//////////////////////////////////////// Normal Mode Led  ///////////////////////////////////
void normalModeOn () {
  digitalWrite(blueLed, LED_ON); 	// Blue LED ON and ready to read card
  digitalWrite(redLed, LED_OFF); 	// Make sure Red LED is off
  digitalWrite(greenLed, LED_OFF); 	// Make sure Green LED is off
  digitalWrite(relay, HIGH); 		// Make sure Door is Locked
//////////////////////////////////////// Read an ID from EEPROM //////////////////////////////
void readID( int number ) {
  int start = (number * 4 ) + 2; 		// Figure out starting position
  for ( int i = 0; i < 4; i++ ) { 		// Loop 4 times to get the 4 Bytes
    storedCard[i] = EEPROM.read(start + i); 	// Assign values read from EEPROM to array
///////////////////////////////////////// Add ID to EEPROM   ///////////////////////////////////
void writeID( byte a[] ) {
  if ( !findID( a ) ) { 		// Before we write to the EEPROM, check to see if we have seen this card before!
    int num = EEPROM.read(0); 		// Get the numer of used spaces, position 0 stores the number of ID cards
    int start = ( num * 4 ) + 6; 	// Figure out where the next slot starts
    num++; 								// Increment the counter by one
    EEPROM.write( 0, num ); 		// Write the new count to the counter
      EEPROM.write( start + j, a[j] ); 	// Write the array values to EEPROM in the right position
    successWrite();
    Serial.println(F("Succesfully added ID record to EEPROM"));
  else {
    failedWrite();
    Serial.println(F("Failed! There is something wrong with ID or bad EEPROM"));
///////////////////////////////////////// Remove ID from EEPROM   ///////////////////////////////////
void deleteID( byte a[] ) {
  if ( !findID( a ) ) { 		// Before we delete from the EEPROM, check to see if we have this card!
    failedWrite(); 			// If not
  else {
    int slot; 			// Figure out the slot number of the card
    int start;			// = ( num * 4 ) + 6; // Figure out where the next slot starts
    int looping; 		// The number of times the loop repeats
    int j;
    int count = EEPROM.read(0); // Read the first Byte of EEPROM that stores number of cards
    slot = findIDSLOT( a ); 	// Figure out the slot number of the card to delete
    start = (slot * 4) + 2;
    looping = ((num - slot) * 4);
    num--; 			// Decrement the counter by one
    for ( j = 0; j < looping; j++ ) { 				// Loop the card shift times
      EEPROM.write( start + j, EEPROM.read(start + 4 + j)); 	// Shift the array values to 4 places earlier in the EEPROM
    for ( int k = 0; k < 4; k++ ) { 				// Shifting loop
      EEPROM.write( start + j + k, 0);
    successDelete();
    Serial.println(F("Succesfully removed ID record from EEPROM"));
///////////////////////////////////////// Check Bytes   ///////////////////////////////////
boolean checkTwo ( byte a[], byte b[] ) {
  if ( a[0] != NULL ) 			// Make sure there is something in the array first
    match = true; 			// Assume they match at first
  for ( int k = 0; k < 4; k++ ) { 	// Loop 4 times
    if ( a[k] != b[k] ) 		// IF a != b then set match = false, one fails, all fail
      match = false;
  if ( match ) { 			// Check to see if if match is still true
    return true; 			// Return true
  else  {
    return false; 			// Return false
///////////////////////////////////////// Find Slot   ///////////////////////////////////
int findIDSLOT( byte find[] ) {
  for ( int i = 1; i <= count; i++ ) { 		// Loop once for each EEPROM entry
    readID(i); 								// Read an ID from EEPROM, it is stored in storedCard[4]
    if ( checkTwo( find, storedCard ) ) { 	// Check to see if the storedCard read from EEPROM
      // is the same as the find[] ID card passed
      return i; 				// The slot number of the card
      break; 					// Stop looking we found it
///////////////////////////////////////// Find ID From EEPROM   ///////////////////////////////////
boolean findID( byte find[] ) {
      return true;
    else {  	// If not, return false
  return false;
///////////////////////////////////////// Write Success to EEPROM   ///////////////////////////////////
// Flashes the green LED 3 times to indicate a successful write to EEPROM
void successWrite() {
  digitalWrite(greenLed, LED_OFF); 	// Make sure green LED is on
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
///////////////////////////////////////// Write Failed to EEPROM   ///////////////////////////////////
// Flashes the red LED 3 times to indicate a failed write to EEPROM
void failedWrite() {
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
///////////////////////////////////////// Success Remove UID From EEPROM  ///////////////////////////////////
// Flashes the blue LED 3 times to indicate a success delete to EEPROM
void successDelete() {
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
////////////////////// Check readCard IF is masterCard   ///////////////////////////////////
// Check to see if the ID passed is the master programing card
boolean isMaster( byte test[] ) {
  if ( checkTwo( test, masterCard ) )
    return true;
    return false;
I doubt you will find anyone on here who will “insert the code” for you. What you will find is a lot of people who will help you do that yourself. We will point you to useful sources, look for bugs in code, give insight to the process, etc., but not write the code for you.
Looking at what you posted, it looks like you need to take some time and read through the DOCS to get a better understanding as to what it takes to make your project work with BLYNK. Once you have a general understanding of how BLYNK works, I suggest taking some time to fully understand, and how to implement, the SimpleTimer (going to be a must for your program to function with BLYNK). Then work through a few of the examples on the Sketch Builder. Once you go through all of that I bet you will have a good idea on how to get your RFID program to communicate with the wonderful BLYNK App.
I wish you the best on your learning adventure.
Also, I forgot to mention, when posting code please use the method described below. (I think the cpp can be excluded)
@Duane_Barker I properly formatted your code for forum viewing. Please take note on how that was done, for the future.
As for your question…
Short answer - NO, this forum is not a code factory :wink:
Long answer - That has already been provided by @Toro_Blanco :+1: As you learn we will assist, but you are the only one able to do the “work”.
Please check out all the links at the top right of this page.
