NEED HELP arduino project
Still the wrong name here
Hey I am making this project where I take data from capacitive soil 1.2 sensor, I need help when it falls below a certain value I want it to trigger a relay which while run for a specific time. Can some one help me. Thanks.
This is what I have have so far, it will not trigger the relay.
int relayPin = 8;
volatile byte relayState = HIGH;
const int AirValue = 650;
const int WaterValue =390;
int intervals = (AirValue - WaterValue)/3;
int soilMoistureValue =0;
  pinMode(8,OUTPUT);
  pinMode(A0,INPUT);
  DebugSerial.begin(9600);
  Blynk.begin(Serial, auth);
  timer.setInterval(1000L, relay);
void relay(){
 if (soilMoistureValue < AirValue && soilMoistureValue > (AirValue - intervals))
    digitalWrite (relayPin, HIGH);
  else {
    digitalWrite (relayPin, LOW);
You already had a topic about this… Please do not make redundant topics.
I merged them both into this original.
Hey for some reason the the relay is not working properly can you help me.
Do you know what could be wrong in the sketch?
Hey can you see my sketch below the relay does not trigger for some reason.
@smity We are not here as code troubleshooters at your beck and call :stuck_out_tongue: Please post ONE request, then wait for someone willing and able to respond on their own timing.
Personally I have no idea, but then I am busy on my own stuff so not really working on your code :wink:
ok, I am sorry.
ok, but what is going on ?
and where is the code to get AirValue and soilMoistureValue values ?
if I were you, I’ll add 2 sliders to simulate values and test relays
:thinking:
20-026711
when I add a virtual switch to the pin the rely is on, it works, but not when I want it to in the sketch, when the value drops below a certain point.
