NEED HELP arduino project
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
Hey I am making this project where I take data from capacitive soil 1.2 sensor,Ii need help taking this sketch and sending it in Blynk app also when it falls below a certain value I want it to trigger a relay which while run for a specific time. Can some one help me. Thanks.
this is arduino sketch I have so far
const int AirValue = 650;   //you need to replace this value with Value_1
const int WaterValue = 390;  //you need to replace this value with Value_2
int intervals = (AirValue - WaterValue)/3;
int soilMoistureValue = 0;
  Serial.begin(9600); // open serial port, set the baud rate to 9600 bps
soilMoistureValue = analogRead(A0);  //put Sensor insert into soil
if(soilMoistureValue > WaterValue && soilMoistureValue < (WaterValue + intervals))
  Serial.println("Very Wet");
else if(soilMoistureValue > (WaterValue + intervals) && soilMoistureValue < (AirValue - intervals))
  Serial.println("Wet");
else if(soilMoistureValue < AirValue && soilMoistureValue > (AirValue - intervals))
  Serial.println("Dry");
delay(50);
Start by reading this:
Then looking at some of the example sketches in Sketch Builder:
https://examples.blynk.cc/
First thank you.Yes I got that working but how would I make it trigger the relay if it reaches certain value. Again thanks.
Something like this?
const int VAL_PROBE = 0; // Analog pin 0
const int MOISTURE_LEVEL = 250; // the value after the LED goes ON
void LedState(int state) {
    digitalWrite(13, state);
    int moisture = analogRead(VAL_PROBE);
    Serial.println(moisture);
    if(moisture > MOISTURE_LEVEL) {
        LedState(HIGH);
    } else   {
        LedState(LOW);
    delay(100);
or something like this?
int relay = 8;
volatile byte relayState = LOW;
const int WaterValue =390;
int soilMoistureValue =0;
  pinMode(8,OUTPUT);
  pinMode(A0,INPUT);
  DebugSerial.begin(9600);
  Blynk.begin(Serial, auth);
  if (WaterValue >=400){
    digitalWrite (relay, HIGH);
  else {
    digitalWrite (relay, LOW);
  delay(100);
this is a clean loop :wink:
so your sketch must look like :
  pinMode(8,OUTPUT);
  pinMode(A0,INPUT);
  timer.setInterval(1000L, relay);
void relay(){
  else {
Thank you, let me run it and see if it works. Is the relay part right in the sketch?
it is just an example
you have to incorporate your
and some other stuff
Is this correct? Thanks
on this sketch I get this error
‘int relay’ redeclared as different kind of symbol
int relay = 8;
  pinMode(8,OUTPUT);
  pinMode(A0,INPUT);
void relay(){
  else {
Since we can’t see the entire sketch (all your Blynk libraries are missing) then we can’t tell if you have another declaration or not.
There is also an unlikely possibility that the name relay is being used as a keyword or something elsewhere? Try relayPin
BTW, if you are going to do this, then perhaps use const int and then actually use the name in lew of the number throughout the sketch…
pinMode(8,OUTPUT);
should be…
pinMode(relay,OUTPUT);
Also… this is unnecessary as the default nature of analog pins is INPUT
Sorry I didn’t understand
Still get the same thing.
int relay = 8;
  pinMode(A0,INPUT);
void relay(){
  else {
Don’t understand what? Life, the Universe and Everything? Or some particular part of my response?
Ah, sorry I found it… this should be at the top of the sketch.
I already have that in the sketch.
Yep, I thought so… you are using the same name relay for BOTH the pin and the function
Yes, but normally they are located at the TOP… thus when I didn’t see it there… :stuck_out_tongue_winking_eye:
Ok now its telling me
“timer” was not declared in this scope
int relayPin = 8;
  pinMode(relayPin,OUTPUT);
  pinMode(A0,INPUT);
void relay(){
  else {
Because it isn’t :wink: you need this BlynkTimer timer; … as per various examples using the BlynkTimer
And now you have the library referenced twice… and still NOT at the top of the sketch
Thanks, it seems it’s working. let me upload it and check it out. Thank you so much.
int relayPin = 8;
  pinMode(A0,INPUT);
void relay(){
  else {
