Need control LED with more than one auth token
Hi all! I’m Jessica . Please help me about control LED with more than one auth token.
Thanks all
Hi Jessica, can you tell us a bit more about what you want to do?
Is this a physical LED that you want to control from more than one mobile device, or an LED widget?
If its an LED widget then it can only have one Auth token associated with it, but you can control it from multiple devices (Arduinos or NodeMCUs) by using Bridge code.
