Nano and ESP8266
I’ve an Arduino Nano connected to an ESP8266-01 firmware v. 0018000902. At power up I get the following text which tells me that I’m connected to my dsl ok.
[19] Blynk v0.4.0 on Arduino Nano
[520] Connecting to mywifi
[3580] 0018000902
[8717] 192.168.0.36
[8747] Connected to WiFi
However, I cannot get to turn on the nano’s led D13. I set the widget switch to GP13 when selected ESP8266 as hardware or to D13 when selected nano as hardware.
I’m using the standard sketch loaded onto the nano.
Where did I go wrong?
TIA
#include <ESP8266_Lib.h>
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
//#define EspSerial Serial  // tried it but no avail
SoftwareSerial EspSerial(8, 9); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
  // Set console baud rate
  // Set ESP8266 baud rate
    // Wait until connected
You can’t set hardware as ESP, must be Nano.
Looks like you are connected to the router but not the Blynk server from your Serial Monitor extract.
Is that all SM gives you?
Yes, it’s all the info I get but I got it working by changing the serial pins from 8,9 to 10,11 don’t ask me why :slight_smile:
Thank you.
You set in the router NAT the 8442 port?
@Franco No, didn’t need to.
NAT is only for incoming ports which initiate a TCP (or UDP) session to a device on a private LAN. No need for outgoing ports to be in that table. Outgoing ports will, most of the time, be random anyway (from the client side).
