Hi, I am converting my applications to Blynk 2.0 and, next to the “terminal not keeping messages when restarting” issue which is being worked on as I can read here, I have one other problem:
When displaying virtual pin values as labeled value or value display widgets, some (not all) values get a mysterious “kW” added next to it. (see screenshot)
It does not seem to be depending on the type of variable used in the code.
I have no idea where this comes from, I did not add these “kW” myself.
Look at the unit of the datastream in your web console and change it for “none”
Thanks a lot, I was not aware there were units in there. Problem solved!
