Hello.I try to used text input for my String but it all way empty i try every thing i could but notthing work.This is my code.
#include <Arduino.h>
#include "BluetoothSerial.h"
#include <BlynkSimpleEsp32_BT.h>
#include "EEPROM.h"
BluetoothSerial ESP_BT;
int Relay = 12;
String code = "xxxxx";
char auth[] = "Bs87he1Gwwq2FfsNxAvheGX99kWOYg8h";
String Passcode;
String UserID;
String Password;
void writeStringToEEPROM(int addrOffset, const String &strToWrite)
byte len = strToWrite.length();
EEPROM.write(addrOffset, len);
for (int i = 0; i < len; i++)
EEPROM.write(addrOffset + 1 + i, strToWrite[i]);
String readStringFromEEPROM(int addrOffset)
int newStrLen = EEPROM.read(addrOffset);
char data[newStrLen + 1];
for (int i = 0; i < newStrLen; i++)
data[i] = EEPROM.read(addrOffset + 1 + i);
data[newStrLen] = '\0';
return String(data);
Blynk.setDeviceName("kit blynk");
pinMode(Relay, OUTPUT);
Blynk.begin(auth);
Blynk.connect();
BLYNK_CONNECTED() {
Serial.println("App Blynk ŕ¸ŕ¸łŕ¸ŕ¸˛ŕ¸!");
BLYNK_WRITE(V1) {
String Passcode = param.asStr();
if (Passcode.startsWith(" ")) {
Passcode.remove(0, 1);
if (Passcode.endsWith(" ..")) {
Passcode.replace(" ..", "\n");
Blynk.virtualWrite(V1, " ");
Blynk.virtualWrite(V0, Passcode);
Serial.println(Passcode);
BLYNK_WRITE(V2) {
String UserID = param.asStr();
if (UserID.startsWith(" ")) {
UserID.remove(0, 1);
if (UserID.endsWith(" ..")) {
UserID.replace(" ..", "\n");
Blynk.virtualWrite(V2, " ");
} Blynk.virtualWrite(V0, UserID);
Serial.println(UserID);
BLYNK_WRITE(V3) {
String Password = param.asStr();
if (Password.startsWith(" ")) {
Password.remove(0, 1);
if (Password.endsWith(" ..")) {
Password.replace(" ..", "\n");
Blynk.virtualWrite(V3, " ");
} Blynk.virtualWrite(V0, Password);
Serial.println(Password);
BLYNK_WRITE(V0) {
String ID = readStringFromEEPROM(1);
String passWord = readStringFromEEPROM(32);
if (param.asInt() == 1) {
if (Passcode == code) {
writeStringToEEPROM(1, UserID);
writeStringToEEPROM(32, Password);
Serial.println("log in succeed.1");
else if ((UserID == ID) && (Password == passWord)) {
Serial.println("log in succeed.2");
digitalWrite(Relay, HIGH);
delay(5000);
else {
Serial.println("log in fale.");
Serial.println(ID);
Serial.println(passWord);
@Atithep_Jarungsathit please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly. Triple backticks look like this:
@Atithep_Jarungsathit youâve edited your post but despite me giving you triple backticks that you can copy and paste, youâve used other characters instead.
Please re-edit your post, and this time use the correct triple backtick characters.
My apologise.Is this correct one?
Yes,
Your problem is that you are declaring global variables for Passcode
, UserID
and Password
at the top of your sketchâŚ
then re-declaring these variables locally within the corresponding BLYNK_WRITE(vPin) functions like thisâŚ
You need to remove the String
declaration from the front of these variable names in the `BLYNK_WRITE(vPin) functions.
Lets see your updated code, proper serial output (not a screenshot) and details of exactly what you are inputting into your widgets.
Iâm try to get text fromV1 to compare with âcodeâ for activate function that create âUserIDâ and âPasswordâ then turn on my Relay ,V2 V3 to compare with âUserIDâ and âPasswordâ with out "code"to turn on my Relay or else end process.this is an update.Thank-you.
#include "EEPROM.h"
int Relay = 12;
String Passcode;
String UserID;
String Password;
Blynk.begin(auth);
Blynk.connect();
BLYNK_CONNECTED() {
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V0) {
delay(5000);
else {
Serial.println("ID ==");
Serial.println(ID);
Serial.println("passWord ==");
Serial.println("UserID ==");
Serial.println("Password ==");
No.
You posted a screenshot of your serial outpit, but I donât want a screenshot, I want the data from the serial monitor copied and pasted, between triple backticks.
I also want to know exactly what characters you typed into the three fields in the app, so that I can make sense of the data that appears in the serial monitor.
It would also be useful to know which virtual pin your âloginâ button widget is attached to, as its not obviously from the code.
Isnât this how you would approach the task of debugging this code?
so sorry.Do you meen this section?
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V0) {
delay(5000);
else {
Serial.println(ID);
Iâm not asking for code, youâve already provided that.
Iâd suggest that you re-read what I wrote.
Do you meen character that i put in âcode ,UserID,Passwordâ?
Yes, along with what appears in your serial monitor when you do this, plus info on what pin your switch is attached to.
@⸎!:P⸎⸎⸎p⸎%⸎K⸎Waiting for connections...
[9]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP32
[8052] BT connect
[11061] BT disconnect
[11061] Disconnected
[22786] BT connect
[22798] Ready
[36871] BT disconnect
[36871] Disconnected
[51946] BT connect
[54963] Ready
log in succeed.2
ID == //characters in eeprom that user create
passWord == //characters in eeprom that user create
UserID == //in put is "myID123" on pin V2
Password == //in put is "12345" on pin V3
Passcode == //in put is "xxxxx" same ask "code" on pin V1
Okay, I give up!
Good luck with your project.
