OG-g
October 18, 2018, 7:24am
1
Im using Wemos D1 mini, max6675, Android and Blynk server.
In both Serial Monitor and thru Blynk app I can read the temperature but it doesn’t refresh.
Any help appropriated.
#include <max6675.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int thermoDO = D6;
int thermoCS = D8;
int thermoCLK = D5;
int LED = D1;
MAX6675 thermocouple;
pinMode(LED, OUTPUT);
thermocouple.begin(thermoCLK, thermoCS, thermoDO);
BLYNK_READ(V4){
Blynk.virtualWrite(V4, thermocouple.readFahrenheit());
BLYNK_WRITE(V3) {
int pinValue = param.asInt(); // Assigning incoming value from pin V3 to a variable
if (pinValue == 1) {
digitalWrite(LED, HIGH); // Turn LED on.
digitalWrite(LED, LOW); // Turn LED off.
void loop(){
Serial.print("F = ");
Serial.println(thermocouple.readFahrenheit());
delay(100);
Gunner
October 18, 2018, 7:40am
2
Keep your void loop()
clean
And use timers for periodically refreshing the data
OG-g
October 23, 2018, 3:14am
3
Can you take a look at my code, My temp. still dose not change in serial and stays at 73.4 in the blynk app.
#include "max6675.h"
char auth[] = "";
char ssid[] = "";
char pass[] = "";
BlynkTimer timer; // Create a Timer object called "timer"!
int thermoDO = D6;
int thermoCS = D8;
int thermoCLK = D5;
int LED = D1; // Define LED as an Integer (whole numbers) and pin D8 on Wemos D1 Mini Pro
int sensorValue;
pinMode(LED, OUTPUT); //Set the LED (D1) as an output
void myTimerEvent()
sensorValue = thermocouple.readFahrenheit(); // reading sensor from analog pin
Blynk.virtualWrite(V4, sensorValue);
BLYNK_WRITE(V3) {
void loop(){
timer.run(); // BlynkTimer is working...
Gunner
October 23, 2018, 5:33am
4
Try using the preferred Arduino pin designations… the Dpin options are not always recognized correctly.
OG-g
October 24, 2018, 2:41am
5
int xSO = 12; //D6; // SO pin of MAX6675
int xCS = 13; // D7; // CS pin on MAX6675
int xNCK = 15; //D8; // SCK pin of MAX6675 (variable SCK cannot be used reserved for RTC)
its the same
Gunner
October 24, 2018, 2:57am
6
Well, I don’t know… nor am I going to dig through your code line by line… i am working on my own projects
But I just noticed that your void loop()
still has invalid info trying to run thousands of times a second.
Take your serial prints and put them in the same function that reads the sensor in the first place… called by a timer of course.
Then if you still see something on the serial monitor, but it never changes… start double checking your sensor read commands, etc. for any issues.
If you DON’T see serial info, then something might be wrong in the entire timed function (not being called from the timer?)
Only you can troubleshoot it properly.
OG-g
October 25, 2018, 3:28am
7
OK I got it to work, their where several small bugs in the code.
btw this is my first project with blynk and SPI.
Thanks for the tips.
Also uploaded the code as reference for anyone who is doing something similar.
char auth[] = "auth code here";
char ssid[] = "wifi name";
char pass[] = "wifi pass";
int xSO = D7; // SO pin of MAX6675
int xCS = D8; // CS pin on MAX6675
int xNCK = D5; // SCK pin of MAX6675
MAX6675 temp;
void myTimerEvent() {
temp.begin(xNCK, xCS, xSO);
Blynk.virtualWrite(V4, temp.readFahrenheit());
delay(100);
Serial.println(temp.readFahrenheit());
void loop(){
OG-g
October 25, 2018, 2:59pm
9
Forgot to delete that, delay is not needed.
